car struggles/bogs...can someone help? Please
I have a B18C1 swap in my 93 Hatchback....the motor is pretty much all stock cept a cai and also the exhaust is dislodged between the header and cat. Well i need help diagnosin(sp?) what my problem is... While going up to speed and keeping the speed constant on the freeway (65-80mph) the car seems to bog/struggle. But on the city streets with just normal driving the car seems to run fine, and also the car would acclerate fine with no struggle at all. It only struggles when keepin a constant speed around 65-80mph... Does anyone have a clue on what i should check out or know the problem so i can fix it? Thanks in advanced, i hope i find the problem soon and get it fixed soon.
Re: car struggles/bogs...can someone help? Please (SjCiViCHB)
think that your problem might be rpm related? Are you running higher rpms for longer periods on the highway?
Re: car struggles/bogs...can someone help? Please (luti)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense »</TD></TR><TR><TD CLASS="quote">think that your problem might be rpm related? Are you running higher rpms for longer periods on the highway?</TD></TR></TABLE>
stock gsr tryanny...always go to fifth gear on the freeway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JICEK9 »</TD></TR><TR><TD CLASS="quote">o2 maybe??? have you thrown any cel's?</TD></TR></TABLE>
o2 sensor was changed when i s wapped the motor in on feburary. And no theres no cel lights at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luti »</TD></TR><TR><TD CLASS="quote">When was the last time youir fuel filter was changed?</TD></TR></TABLE>
Fuel Filter? i havent changed the fuel filter ever since i've had the car. Its about 5-6 years.
thanks for the feedbacks though guys...i really really appreciate it.
what about trying to clean out your intake manifold? Spray some carb cleaner in there while the car is running... and just rev it up to clean it out... I did that a few times when the same problem was happening to me... worked fine after that.
Re: (CNY Hatch)
Definetly change the fuel filter. Mine caused those same basic problems, its cheap and easy too, and cant hurt, just good preventitive maintenence.
What about fuel pump, is it the stock pump, or an upgraded one for the new motor?
Re: (gen 5 hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gen 5 hatch »</TD></TR><TR><TD CLASS="quote">look at my thread i have the same problem wit the same swap in the same car
so did you fix your problem?
Re: (CNY Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNY Hatch »</TD></TR><TR><TD CLASS="quote">what about trying to clean out your intake manifold? Spray some carb cleaner in there while the car is running... and just rev it up to clean it out... I did that a few times when the same problem was happening to me... worked fine after that.</TD></TR></TABLE>
that actually can be a bad idea, the carb cleaner could detonate causing a explosion in the intake manifold... not exactly the best thing for it.
Re: (u0f)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u0f »</TD></TR><TR><TD CLASS="quote">
that actually can be a bad idea, the carb cleaner could detonate causing a explosion in the intake manifold... not exactly the best thing for it.</TD></TR></TABLE>
whew....okay. Ill pass on that idea then. Thanks!
