H22 swap
Old Sep 14, 2005 | 03:39 PM
ernie2409's Avatar
Default H22 swap
First, I have searched and cant find this exact info. I have a 96 prelude si w/ h23(obd II). I'm planning on doing an h22 swap soon. I found a 92-95 obd1 jdm complete swap for a good price. It comes w/ everything encluding ecu and harness. The problem is that the harness is for right hand drive. Will my current harness work? If I have to use the new harness what mods do I have to do to make that work? Last one, Any other chages other that the ecu for the obd1 to obdII change.Thanks
Old Sep 14, 2005 | 05:38 PM
tdo's Avatar
tdo
Default Re: H22 swap (ernie2409)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ernie2409 &raquo;</TD></TR><TR><TD CLASS="quote">First, I have searched and cant find this exact info. I have a 96 prelude si w/ h23(obd II). I'm planning on doing an h22 swap soon. I found a 92-95 obd1 jdm complete swap for a good price. It comes w/ everything encluding ecu and harness. The problem is that the harness is for right hand drive. Will my current harness work? If I have to use the new harness what mods do I have to do to make that work? Last one, Any other chages other that the ecu for the obd1 to obdII change.Thanks</TD></TR></TABLE>
i dont think you searched hard enough. anyways, yes you can use your stock harness but you will have to wire vtec and you will need a obd2 to obd1 conversion harness.
Old Sep 14, 2005 | 08:16 PM
LudeyKrus's Avatar
The harnesses are the same on both USDM and JDM motors; however you will need to swap over the fuel rails and use the old H23 fuel rail.
Old Sep 14, 2005 | 08:21 PM
AndyD's Avatar
Default Re: H22 swap (tdo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tdo &raquo;</TD></TR><TR><TD CLASS="quote">
i dont think you searched hard enough. anyways, yes you can use your stock harness but you will have to wire vtec and you will need a obd2 to obd1 conversion harness.</TD></TR></TABLE>
93+ Preludes all were pre-wired for VTEC.
I would find out the laws regarding converting an OBDII car to OBDI. In my state, it is illegal.
Old Sep 14, 2005 | 10:15 PM
mgags7's Avatar
i dont know about in NJ, but here in NC i had to get an obd2 computer to work enough for me to pass inspection....
this info has all been posted up before....
oh and i have yet to find where my car was pre wired for vtec.....
Old Sep 14, 2005 | 11:55 PM
tdo's Avatar
tdo
Default Re: H22 swap (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
I would find out the laws regarding converting an OBDII car to OBDI. In my state, it is illegal.</TD></TR></TABLE>
that i didnt know. learn something new everyday.
Old Sep 15, 2005 | 04:57 PM
ernie2409's Avatar
Would I have to wire vtec if I went with an h22 that was from 96+?
Old Sep 15, 2005 | 07:15 PM
steveobb4's Avatar
My 94 s was NOT pre-wired for vtec. Trust me i know.
snapscooter
Dec 10, 2013 05:54 PM
marcusgnf
Apr 22, 2007 04:21 PM
civichb97
Dec 9, 2002 01:22 PM
