4spd to 5spd in a 91 civic hatch?
Would i need to change anything if i were to put a DX or SI 5spd tranny into my 91 Civic Hatch STD that originally came with a 4 spd? If i do... im in a bind cause the driver side CV Joint will NOT come out of the hub! i've tried punches....BFH's... and a few other things but it still will not come out! any suggestions on that also? Thanks!
You don't have to change everything, all should be happy and live together once in. If you are having trouble removing the axle from the hub you can try a gear puller, those work wonders
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 »</TD></TR><TR><TD CLASS="quote">Would i need to change anything if i were to put a DX or SI 5spd tranny into my 91 Civic Hatch STD that originally came with a 4 spd? If i do... im in a bind cause the driver side CV Joint will NOT come out of the hub! i've tried punches....BFH's... and a few other things but it still will not come out! any suggestions on that also? Thanks!</TD></TR></TABLE>
That's weird, because my driver side axle did the same thing. I ended up mutilating the entire operation and just got a new hub. I had to get new hubs anyways to accomodate integra axles. I recommend you go to pick-n-pull and do the same. Funny how yours was the drivers side too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 »</TD></TR><TR><TD CLASS="quote">well the gear puller didn't work.... are the axles the same for the 4 and 5 speeds? </TD></TR></TABLE>
No the std axles are smaller in diameter. In order to use dx/si axles you will need the hubs from a dx/si. std axles will work fine with the si tranny though
yeah when i did my clutch i ran into the same problem and it really pissed me off cuz it was after 3 hours and 5 beers...
anyways you can still work with it stuck on the hub and i'd assume that your axles will work with the new tranny since they are both d-series and what not
But just to let you know, you should get a new clutch and maybe a flywheel while your at it
too bad you dont live a little closer... im about an hour or so away(lima)... if gas prices werent so high then id be up there to help you out... i did the same exact swap... i had the 4 speed on my Z6 and just put a dx in about 2-3 weeks ago... i had my buddy over to help me out and he just put the axle nut back on a few turns and then he just ripped on it with a bfh... came out pretty easy... try that out and see if it works
-Josh
-Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide »</TD></TR><TR><TD CLASS="quote">too bad you dont live a little closer... im about an hour or so away(lima)... -Josh</TD></TR></TABLE>
actually... im goin to school down there in Lima... im goin to the University of Northwestern Ohio.... but i have my car up in bellevue which really sucks!!!! lol thanks for the input
actually... im goin to school down there in Lima... im goin to the University of Northwestern Ohio.... but i have my car up in bellevue which really sucks!!!! lol thanks for the input</TD></TR></TABLE>
are you currently going to school at UNO or are you planning on going there? if you are going to school here what do you drive? i have a red hatch with a black crx front end conversion and bronze rims... maybe you can bring the car down and we can swap the tranny out down here? lmk
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">What? Another Lima person?
to that.</TD></TR></TABLE>
yeah you actually helped me out a lil bit when i was doing my swap... you got me in contact with josh(black si hatch w/ dohc zc)... did you go to school at UNO too? the funny thing is i moved up here from miami... lol
-Josh
to that.</TD></TR></TABLE>yeah you actually helped me out a lil bit when i was doing my swap... you got me in contact with josh(black si hatch w/ dohc zc)... did you go to school at UNO too? the funny thing is i moved up here from miami... lol
-Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide »</TD></TR><TR><TD CLASS="quote">yeah you actually helped me out a lil bit when i was doing my swap... you got me in contact with josh(black si hatch w/ dohc zc)... did you go to school at UNO too? the funny thing is i moved up here from miami... lol
Here is the deal, I grew up in Lima, went to Lima Senior, moved to Florida and graduated there, and now go to UM. But I will never forget the original hometown
Lima senior... ewwwww... lol i lived in dayton til i was 10 then moved to tampa for 6 years then miami for about 1.5 years and then ive been in Lima for a little over a year... cant wait to get out of this place... lol... sry no more thread jacking
-Josh
-Josh
can't bring it down....tranny's broken and i already have it out of the car... and was finally able to get that axle out of the car...what a pain in the ***!!!! and i am attending UNO right now... if i get the brakes fixed ill be driving my 91 Eclipse down there this next week
later on!!!
later on!!!
is your eclipse by any chance a turbo? i talked to some kid and his friend in a supercharged t-bird a few weeks back... but i thought they were from columbus... did you stop in at advance auto on elida rd? i remeber talking to a kid there to about his eclipse
-Josh
-Josh
no... mine ain't turboed.... and was the guy u happened to talk to about 6 foot 9 and drives a 98 Eclipse with a wing and bod kit? my friend from high school has one all tricked out and ****... mine burns oil and likes to overheat! lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fork »</TD></TR><TR><TD CLASS="quote">yeah it should be cake for the swap, as far as the axel, thats a new one by me</TD></TR></TABLE>
well if u want sometime next week...stop by the school and ill show u my eclipse... it's nothin special but it ***** and gits!!!! also... my eclipse likes to stall.... ill start it up in the morning and drive it around... but if i shut it off and try to start it back up... it stalls almost immediately!!! ever hear of this????
elliott24m
Apr 1, 2017 12:23 PM
brandIZZLE!
Dec 21, 2007 01:41 PM
