slave cylinder
Old Sep 14, 2005 | 12:28 PM
stickman12's Avatar
Default slave cylinder
I have a 92 civic and the clutch cylinder has been acting up. (don't know if it is the master or slave that has the problem). So I tried to manually bleed the system, and I can't seem to get any pressure at all now. Please help, any sugg. taken.
Old Sep 14, 2005 | 01:22 PM
Jowee's Avatar
Default Re: slave cylinder (stickman12)
How did you bleed the system? What's it doing exactly?
Old Sep 14, 2005 | 01:31 PM
ThatsMyEG's Avatar
Is it leaking fluid? if so your master cylinder is probably bad or you have a leak somewhere else or your just bleeding them wrong..
Modified by ThatsMyEG at 3:04 PM 9/14/2005
Old Sep 14, 2005 | 02:09 PM
BenzTek134's Avatar
Default Re: slave cylinder (ThatsMyEG)
how did u bleed the slave cylinder? u sure u were doing it correctly?? do u have fluid in ur master cylinder?
Born2Build
May 22, 2011 06:02 PM
djkurious
May 19, 2009 04:22 PM
Jay Dirt
Oct 26, 2007 05:27 PM
redman223
Jun 3, 2007 03:58 PM
97teg415
Aug 1, 2002 09:45 AM
