B16a2 Vtec
Old Sep 14, 2005 | 11:04 AM
E46Kid's Avatar
Default B16a2 Vtec Problem
Alright, so i have a 00 civic si..i just bought it. A friend was telling me that i have no vtec it trys to kick in at 5500 but kicks out and keeps accelerating..cars runs alright but no vtec..he said it could be either my dizzy or my vtec solenoid..car does have oil and fuel..did recent tune up..if i get a new distributor..which what we he think is the cause, can it be from a gsr..and could that be the problem of vtec not kicking in? and does it have to be from a b series engine the one i have now is gsr..but were not sure if that thiers something wrong anyone know what the problem could be..
We also tried switching ecu's from his 00 si..it didnt make a difference so i know it could not be my ecu..
Modified by 00EM1 at 10:06 PM 9/14/2005
Old Sep 14, 2005 | 11:15 AM
sicky's Avatar
grammer nawzi
Default Re: B16a2 Vtec Problem (00EM1)
Before you do that, take out the Vtec selenoid and just clean it with some brake cleaner and then try again. It might just be junked up
Old Sep 14, 2005 | 11:20 AM
Suck my DX's Avatar
Default Re: B16a2 Vtec Problem (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">Before you do that, take out the Vtec selenoid and just clean it with some brake cleaner and then try again. It might just be junked up</TD></TR></TABLE>
double check ur oil level and make sure that it is correct
u will be fine running a gsr ecu...
so did u say that vtec doesnt work at all or kicks on and off?
im pretty sure it doesnt have anything to do with ur dizzy...
Old Sep 14, 2005 | 11:55 AM
FalkenSiR's Avatar
Default Re: B16a2 Vtec Problem (Suck my DX)
Dizzy is out of question for sure...
How many miles on the engine again?
Old Sep 14, 2005 | 12:17 PM
Sijray21's Avatar
double check the oil level as said before. Vtec does not engage below a certain oil pressure. Also make sure the engine is warm when doing this :-p, some people over look it.
Old Sep 14, 2005 | 12:22 PM
Suck my DX's Avatar
Default Re: (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote"> Also make sure the engine is warm when doing this :-p, some people over look it.</TD></TR></TABLE>
lol dont u just love it when people say my vtec isnt working and theyre trying to make it engage on a cold engine...lol or even worse in neutral...
Old Sep 14, 2005 | 09:01 PM
E46Kid's Avatar
okay..car is warmed up..but yes it kicks in and out at 5500 rpm car only has 47000 miles..i should be able to hear vtec kick in hard especially with b16..(Example) i raced a 91 integra and i barely won by a fender length..i shoulda dumped on him when vtec kicked in but it never did.
How do i clean the solenoid take it off? and clean inside?..(i know how to check oil)also how do i check my oil pressure.
Im new to this so please explain it very easy thankx.
Modified by 00EM1 at 10:13 PM 9/14/2005
Old Sep 14, 2005 | 09:38 PM
Suck my DX's Avatar
Default Re: (00EM1)
u will not be able to know what ur oil pressure is until u get ur oil pressure gauge....the solenoid is attached by 3 10mm bolts on the exhaust side of ur head...when u take it off take a look at the screen and see if it is gunked up...if it is i usually remove it and hit it with sum brake cleaner real quick...make sure u dont get brake cleaner on any of the rubber gaskets...it will cause em to dry up and potentialy leak...if it is not clogged u will have to check if the solenoid is good or not...also try grounding the pressure switch to the chassis and see if it makes a difference
Old Sep 14, 2005 | 09:47 PM
E46Kid's Avatar
pressure switch?
Old Sep 14, 2005 | 09:53 PM
Suck my DX's Avatar
Default Re: (00EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00EM1 &raquo;</TD></TR><TR><TD CLASS="quote">pressure switch?</TD></TR></TABLE>
ull see a wire that has been screwed down under a small bolt on ur solenoid...sometimes the bolt can get loose and cause a faulty connection...u have to run that wire to a chassis point where it will be making clean contact with bare metal...sand off the paint in the small spot where u will be mountin it...
are u throwin any codes?
Old Sep 14, 2005 | 10:03 PM
E46Kid's Avatar
not throwing any codes..
Old Sep 15, 2005 | 10:43 AM
E46Kid's Avatar
alright i cleaned my vtec solenoid with brake cleaner spray..car is still not engaging vtec right still bogs in and out at 5500 rpm..is thier a place where i can take this to get fix obviously diy isnt work..
Old Sep 15, 2005 | 01:47 PM
Suck my DX's Avatar
Default Re: (00EM1)
did u do all the other stuff i told u to do ?
check ur im i explained it all right there
Old Sep 15, 2005 | 01:56 PM
johnnylaw's Avatar
Default Re: (00EM1)
hook a test light up to it and take it for a drive. if it lights then it is probably the solenoid. if it doesnt then id say its oil pressure. give it some fresh oil
Old Sep 15, 2005 | 09:08 PM
E46Kid's Avatar
alright its working.. vtec started realising its self after i cleaned it .....33 miles later and a full tank of gas i started engaging vtec like crazy ..thanx to suck my dx ur advice helped me solenoid was probably plugged then after driving to stockton from modesto it started kicken in well
Old Sep 15, 2005 | 10:47 PM
K i l l a B e e.'s Avatar
Default Re: (00EM1)
so diy does work =].
Old Sep 16, 2005 | 09:07 AM
E46Kid's Avatar
Default Re: (allday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allday &raquo;</TD></TR><TR><TD CLASS="quote">so diy does work =].</TD></TR></TABLE>
yup
Old Sep 16, 2005 | 11:31 AM
Suck my DX's Avatar
Default Re: (00EM1)
glad i could help
Old Sep 16, 2005 | 01:03 PM
E46Kid's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">glad i could help</TD></TR></TABLE>
good job
K20b-Curb
Dec 24, 2014 10:43 AM
Em1_coupe
23
Feb 20, 2008 07:11 PM
92H23VTEC
Nov 25, 2007 06:49 PM
mikeaitken
Apr 1, 2007 02:22 PM
E46Kid
Aug 22, 2005 10:37 AM
