2000 civic si help!!!!!!!!
Old Sep 14, 2005 | 10:36 AM
jsteezy1290's Avatar
Default 2000 civic si help!!!!!!!!
ok i bought a 2000 civic si today from a repo auction so i dont know much about it.. first off the motor is in the trunk of the car. i noticed it is a b18 block which is not correct.. the head is there and i didnt look at it to well but it looked ok. now what i want to know is what b16 motors will fit in the car without modifications? such as rewiring.. would it be easier to use the b18 block and put a b16 head on it. i have some knowledge to this. i put a b16 in a crx once but that was a couple years ago so i need some help.
Old Sep 14, 2005 | 10:57 AM
Default Re: 2000 civic si help!!!!!!!! (jsteezy1290)
also how do i tell if its a b16 head? and a ls tranny?
Old Sep 14, 2005 | 10:59 AM
b204dr's Avatar
sell the engine you have and buy a 00 b16 if you want the stock effect other wise slap a b16 head on your b18 block( which is it a b18c block or b18b?) as for trannys look at the stamping !
Old Sep 14, 2005 | 11:08 AM
HitEm'Up's Avatar
obdII motor to bolt up
Old Sep 14, 2005 | 11:10 AM
JDM97EK's Avatar
If I were in your shoes I would Keep the B18 block and throw the B16 head on it. I found you get a much faster rev and poss. a little more power off the line. Also be sure to use B18 head bolts, ( they are longer) because when I did the swap I accidently used B16 bolts and stripped the holes in my block. As for the LS tranny look for the stamp on the side.
Old Sep 14, 2005 | 11:41 AM
jaydeeumms's Avatar
Default Re: 2000 civic si help!!!!!!!! (JDM97EK)
make sure you look over the head thuroughly though, dont forget to check cams and **** like that, wouldnt want to ruin a motor that might not have been fucked up in the first place... but yeah go with the b18 block and keep the head if its in good enough condition.
Old Sep 14, 2005 | 11:53 AM
Default Re: 2000 civic si help!!!!!!!! (jaydeeumms)
how do i find out if my head is even a b16 head? not sure on the block i will now tomorow and have pics for all of you. regardless i plan on taking the head to the machine shop to get tested.
Old Sep 14, 2005 | 03:01 PM
bump!!!!!
Old Sep 14, 2005 | 07:35 PM
bump!
Old Sep 15, 2005 | 11:51 AM
ok the block is a b18a1, and the head says pr3-2. the head is scared from the cams and i took it to my shop and they said they couldnt fix it. looks like it was due to lack of oil. what setup is this?
Old Sep 15, 2005 | 12:24 PM
blaze the chemi's Avatar
PR3-2 sounds like a B16 head. I want to make sure though, but I believe I was seeing this all over my head when I was doing my rebuild. That sucks that it is damaged. Look at the exhaust manifold side. You'll see 4 circles with numbers in them. This tells you the year and stuff. Can't remember what means what though. Good luck with your project.
Old Sep 15, 2005 | 12:42 PM
1337 Si's Avatar
I have an 00 Si and will sell my b16a2 swap. Motor has DC4-1 AEBS manifold and a quaife exedy clutch and toda flywheel. Interested? PM me if you are.
Old Sep 15, 2005 | 01:13 PM
Default Re: 2000 civic si help!!!!!!!! (1337 Si)
any help people!!!
Old Sep 15, 2005 | 02:08 PM
slammed00si's Avatar
if you want a stock motor for an em1 it would be a b16a2. the head should be an si head from the pr3 stamping your talking about. does it have a transmission and wiring harnes. if it does just buy a b16a2 longblock and call it a day.
Old Sep 15, 2005 | 02:21 PM
Default Re: 2000 civic si help!!!!!!!! (slammed00si)
yea it has the wiring and tranny, but should i get a b16a2 head again? does this setup starve the head for oil?
Old Sep 15, 2005 | 02:24 PM
what block is it? b18a/b b18c?
it shouldnt starve the head for oil the oil pump may be bad in the block. just for simplicity i would buy the longblock and call it a day sence the block is unknown.
Old Sep 15, 2005 | 02:43 PM
the block is a b18a1.
Old Sep 15, 2005 | 02:44 PM
doesnt anyone have knowledge on the b16a2 head on the b18a1 block
Old Sep 16, 2005 | 04:02 AM
bump anyone!!!!!!!
Old Sep 16, 2005 | 07:21 AM
1337 Si's Avatar
Interested in mine at all.
Old Sep 16, 2005 | 09:31 AM
i have a b16 out of a del sol for 800 that i can buy and thats everything
Old Sep 16, 2005 | 10:38 AM
SE7EN3S's Avatar
I remember a company making an engine called "The Beast". Didn't they use a B18 block and B16 head... **** that thing was rated at 297 horses or somthing.
If the head and block are good... I'd shoot for a Beast Replica!!
Old Sep 16, 2005 | 12:44 PM
Default Re: 2000 civic si help!!!!!!!! (SE7EN3S)
does'nt anyone know anything about this stuff?????
Old Sep 16, 2005 | 04:22 PM
ditch the block its an obd1 ls. it means its old as hell. just get a b16a2 longblock and call it a day. you can do the b18a1 but it will need to be rebuilt from the sounds of it. basicaly if the head is crap i bet the block is to.
Old Sep 17, 2005 | 05:53 AM
ya but just because the head is crap doesnt mean the block is. isnt this motor setup supposed to be a asskicker?
