Rear disk spindle problem(hub\bearing)
Old Sep 14, 2005 | 09:44 AM
DC4_MADMAN's Avatar
Default Rear disk spindle problem(hub\bearing)
Ok so I got me a set of Teg TAs from PasswordJDM, and I am in the process of rebuiling them with new OEM parts. I have completely stripped them down to just the TA and spindle. My problem-
One hub\bearing assemply came off with no issue, the other one did not. It left the rear bearing cap on the spindle, I know this has to have happened to many people before, so what can I do(other than take it to a machine shop)?
I had thought of heating it up with a heat gun in the hopes of expanding the cap and it would slide off.(have not tried it yet)
What do you think?
Hope I explained it well enough, I'll try and get pics to make it more clear.
Old Sep 14, 2005 | 10:23 AM
DC4_MADMAN's Avatar
Default Re: Rear disk spindle problem(hub\bearing) (4door_demon)
Ok, Pics-
Stuck bearing cap on spindle-
What spindle should look like-
Any thoughts appreciated.
Old Oct 4, 2005 | 07:25 PM
Hondacivic90ed's Avatar
get a die grinder w/ a cutoff tool and just cut a groove straight up and down on the section of the bearing that is stuck, it is only stuck because of the resistance fit on the spindle, so when you cut into that bearing, the stress that is holding it on is gone and it will pop off, believe me I have done this a million times with both ft & rr wheel bearings
SQ is the SQUAD
Suspension & Brakes
Jul 18, 2006 03:52 PM
DC4_MADMAN
Suspension & Brakes
Sep 14, 2005 11:57 AM
Old_Honda
Jul 20, 2005 09:27 PM
jason_alt
Nov 21, 2004 10:14 AM
