Honda S2000 Honda S2000
Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed?
Old Sep 14, 2005 | 07:19 AM
coffen's Avatar
Default Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed?
Hi All,
You are my last hope....I installed an AEM V2 cold air intake, as well as, a Comptech Header and Catback. Now and at anytime for no reason I throw a check engine code P0411: Secondary Air Injection System Incorrect Flow Code. I can't tie it with anything...ex. High RPM, Low RPM, Etc. The "kids" that did the work for me are clueless....Honda just keeps troubleshooting it and says it's fine. Then bam it trips again. Any thoughts or suggestions for a work-around would be greatly appreciated.
Chris
Old Sep 14, 2005 | 07:45 AM
WowOzYouRock's Avatar
Default Re: Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed? (coffen)
"secondary air injection" means ur secondary O2 sensor (the one in the cat) .. same thing happen when i installed my header and exhaust too ... replace it with a new one, its about 200 bux (ouch) ... i got mine for FREE ...
Old Sep 14, 2005 | 09:26 AM
Mr. Projekt's Avatar
* B A N N E D *
Same thing happened to a friend's S, his secondary O2 sensor just lost its tip somewhere in the exhaust stream. The only difference is that the Honda mechanic was able to pinpoint the actual o2 sensor.
I don't think its $200 for the sensor.. try http://www.majestichonda.com
BTW Not connecting the blowby hose will throw a CEL. Also make sure your airpump hose that dumps into the intake is also not kinked or restricted, as that will throw a CEL also. I think that could be another variation of "Secondary Air Injection".
Old Sep 14, 2005 | 09:48 AM
Default Re: Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed? (Sideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">
BTW Not connecting the blowby hose will throw a CEL. </TD></TR></TABLE>
no it doesnt!!! i dont have one right now and its all gravy
Old Sep 14, 2005 | 09:49 AM
* B A N N E D *
Default Re: Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed? (Y2K_S2K)
It lit on mine when i forgot... MY MUGEN CATCH CAN!!! BAHAHAHHAHAHA
Old Sep 14, 2005 | 09:55 AM
coffen's Avatar
Is it easy to install...can I just crawl underneath vehicle and pinpoint the sec o2 sensor or what?....sorry I'm a noob when it comes to sgrewing around with these cars.
Old Sep 14, 2005 | 09:59 AM
* B A N N E D *
When I say the mechanic pinpointed the o2 sensor, I meant that he was able to trace the cause of the problem all the way back to a faulty O2 sensor. It's also a lot easier to trace electronic malfunctions than trying to trouble shoot all your vacumm lines, which would probably take them forever if they can't diagnose a CEL.
Old Sep 14, 2005 | 10:06 AM
how you gonna tell me its not $200!!!!?
ok i went to the site the gave and found this
http://www.hondaautomotivepart...+PIPE
HA! in yer face
Old Sep 14, 2005 | 10:22 AM
* B A N N E D *
ok i admit i didn't even look myself, but it was a good place for him to start. i got a new sensor off ebay for $80. happy now?
Old Sep 14, 2005 | 05:55 PM
Kenso's Avatar
HT White Ops
P0411 refers to a problem with the air injection system, not the secondary O2 sensor. I recall Jack at P1 Auto created a thread about this problem with an S2K he was working on, never heard what the resolution was though. Maybe he'll see this thread and chime in. I've never encountered that particular problem with an S so I don't have any advice off the top of my head for you.
Old Sep 14, 2005 | 06:31 PM
* B A N N E D *
Default Re: Has anyone had this problem with '02 s2000 throwing a p0411 after mods installed? (Kenso)
This narrows it down a bit. I'm leaning towards the emissions air pump system.
Old Sep 15, 2005 | 06:05 AM
devnull's Avatar
http://www.s2ki.com/forums/ind...05368
Fix it and make sure you pull the ECU fuse for 5 minutes and then reset the idle correctly.
kaoz314
Oct 10, 2012 01:26 AM
Evil-Mpire
Jul 2, 2010 10:35 AM
94dc2
Honda S2000
May 1, 2008 03:02 AM
Berry Pepper
Oct 24, 2007 08:11 AM
sackdz
Nov 4, 2003 06:40 PM
