B16A 92-93 Integra (XSi)
Old Sep 14, 2005 | 05:45 AM
92civichatch1's Avatar
Default B16A 92-93 Integra (XSi)
is this a normal B16 that can be put into a 92 hatchback. i have never heard of an integra XSi. my plans of the LS swap fell through and this motor came up. i just wanted to make sure it was a B16a that was able to go into my hatch. the p30 ecu will work the best right
Old Sep 14, 2005 | 05:48 AM
JDMlyfestyle's Avatar
Yes the XSi was either a JDM or EDM model of an integra. but you need the following to put it in your hatch.. also you might have a Cable tranny so you would need a cable to hydro conversion. if you have a hyrdo cable then everything else should be all good..
92-95 EG and Del Sol with 94-2000 GS-R B18C(including Integra Type R) & 93-97 Del Sol Vtec & 99-00 Si B16a2
Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used.
Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year.
ECU: Use ecu that came with the Engine with proper wiring modifications. For those who do not wish to use OBDII ecu's. For the B16a2 Si motor use the JDM P30 Ecu. Other wise you may use a Chipped P28 with the Proper Programing.
Electrical Differences: B18C1 add air intake Bypass wiring. Cx and Vx need to conver to 4 wire o2 sensor. Non Vtec models need to be wired for Vtec solenoid and Vtec Pressure. All models Modify stock harness to fit. add knock sensor if you are not using a Chipped p28 ecu. Hasport Harness for B18C1(GSRmotor) part #EGDX-GSR
Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
Upper Radiator Hose: For Engines using b16a or Type R Head use 94-97 Del Sol Vtec Hose. For Engines with GSR head use 94-up GSR hose
Lower Radiator Hose: 94 Delsol Vtec
Throttle Cable: For Engines with B16a head, use 94 Del Sol Vtec. For Engines with GSR (B18C1) head use 94 GSR. For Engines with Type R head Use 98 Type R
Clutch Hydraulics: Stock
Air Conditioning: 94-95 Del Sol Vtec A/C Bracket
Special Instructions: Using OBDII ECU involves wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an adapter harness will cut down on alot of potential problems.
Special Considerations: US motors are smog legal as long as the motor is from the same year or later. Japanese type R motors are very potent and wiring is relatively easy with ecu adapter harness. The B Series engine swaps into these year vehicles are by far the easiest. there are honda mounts available to bolt those engines directly in and the wiring is by far the simplest. The majority of people opt to put in a B18C, B18B, or 94-95 Del Sol B16a and those bolt in directly using Del Sol Vtec Mounts. the Del Sol mounts are the same as the 94-up Integra mounts with the exception of the A/C bracket.
Old Sep 14, 2005 | 05:55 AM
Default Re: (JDMlyfestyle)
this is what hmotorsonline considers the whole swap...
- Motor
- Cable Tranny (YS1)
- ECU (PR3)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
i have a hydraulic trans right now. is going to a cable a tough job
Old Sep 14, 2005 | 07:47 AM
jdmbsol21's Avatar
Default Re: (92civichatch1)
yea the integra xsi is the jdm g2 gsr integra "XSi -1.6L B16A DOHC Power Everything...(GS-R Package)"
Old Sep 14, 2005 | 08:54 AM
stretch_that_motha's Avatar
This is the exact swap in my car. Its quite fun in my HF
Old Sep 14, 2005 | 09:16 AM
hatchish's Avatar
ive got a xsi motr in my hatch no different then a normal b16 but mine came with the hydro tranny i guess they started putting hydro in after 92 also the map isnt mounted on the throttle body in the xsi so mine is just hangin around
D15b Sol
11
Jun 27, 2009 01:37 PM
skUnK2jdm
Dec 1, 2008 04:04 PM
tuner320
Jun 4, 2007 01:11 PM
BLK JDM
May 31, 2003 10:34 PM
ShortbusEK
16
Feb 20, 2002 09:30 PM
