Axle help. Plz!! pics wanted
Old Sep 14, 2005 | 05:25 AM
CivicScorpion69's Avatar
Default Axle help. Plz!! pics wanted
Hey guys. I'm pretty solo on my engine swap and if something doesnt go right i walk away and read. well it seems to me my axles arent in al the way. could just be me freaking out. when in gear they wont move but they just seem to be not in. maybe 1/8 of an inch? i have everything else connected as well. when i try to tourque the axle nut (how much is the btw) it doesnt tighten much. anyone have a pic of their axles? thank you
Old Sep 14, 2005 | 05:28 AM
JDMlyfestyle's Avatar
when i install the axles i always take a piece of wood a 4"x4" x 2" thick piece and tap the axle til it mates with the tranny. Also the torqe spec on the axle is 135 ft lbs if my memory serves me correct
Old Sep 14, 2005 | 05:30 AM
is this achievable with everything connected? ie brakes shock ball joint etc..?
Old Sep 14, 2005 | 05:34 AM
it could be achieveable. may have to use a skinnier piece of wood just be sure its strong enough to not break.
I dont recommend using metal because you can mushroom the end of the axle and that you do not want
Old Sep 14, 2005 | 05:38 AM
so there is no possible way that just sliding it in like i did when i first connected it that it went in all the way?
Old Sep 14, 2005 | 05:40 AM
well you gotta use some force to push the axle in til it clips in place. i learned the hard way by loosing my grip and hitting my head on the control arm so now i just force it in as much as possible without hurting my self and using the hammer and wood meathod.
92civichatch1's Avatar
Default Re: (JDMlyfestyle)
the torque spec is either 130 or 135 ft. lbs and u have to have the axel fully in the trans there should be no room. check your splines on the axel sometimes the slightest lil nic will hold u up. otherwise use the block of wood as mentioned before.
Old Sep 15, 2005 | 05:37 AM
should I disconnect everything? brakes ball joint etc... or just take the wheel off and wack away?
ralphieg
Oct 2, 2012 06:36 PM
bara6075
Oct 3, 2007 04:36 PM
full Circling
Jul 23, 2004 11:37 AM
tecnic1
Jul 11, 2003 07:23 PM
BoM
Aug 16, 2002 10:46 AM
