LUG NUT!!! HELP HELP....
Old Sep 13, 2005 | 10:47 PM
teamm_AP1's Avatar
Default LUG NUT!!! HELP HELP....
Okay guys. I'm turning to honda-tech once again. I've been searching the net for an hour but no luck. im soo pissed. I lost my LUG NUT KEY and i'm trying to figure out what brand it is. This is not the ordinary hex nut. I'll attached some pics, sorry the pics are a bit crappy because i used my camera phone. Thanks in advance.
Old Sep 14, 2005 | 12:25 AM
teamm_AP1's Avatar
bump
Old Sep 14, 2005 | 07:32 AM
CB7.v2's Avatar
go back to the place where you bought them and ask for the brand and/or another key. stop by a rim shop and see what they have that will work. otherwise, wedge something into it and remove them; some even consider welding an adapter to aid it's removal.
Old Sep 14, 2005 | 08:05 AM
gabebauman's Avatar
Default Re: LUG NUT!!! HELP HELP.... (MiSCHiEF_EP)
I had some lugs that where similar to that a few years ago...both back wheels' lug nuts got stripped. I ended up taking one of the front lugs nuts to SEARS and a 12mm hex key/allen wrench fit so I went home and put the long end of the wrench into my jack handle/bar and they came right off. Never used those lugnuts again...lol.
The Hero
good luck...hope I helped.
Old Sep 14, 2005 | 11:49 AM
teamm_AP1's Avatar
Default Re: LUG NUT!!! HELP HELP.... (gabebauman)
I tried that already. It wont work...
Old Sep 14, 2005 | 11:57 AM
my9thtry's Avatar
gator grip socket might work?
Old Sep 14, 2005 | 12:34 PM
pingaturbo's Avatar
Also try a 3/8 extension
Old Sep 14, 2005 | 01:30 PM
teamm_AP1's Avatar
i'll try those suggestions soon.... damn it... someone gotta know wat the brand is....?
fist person with the correct answer will recieve $5 from me. thanks!!!
Old Sep 15, 2005 | 12:54 AM
teamm_AP1's Avatar
Default Re: (MiSCHiEF_EP)
Old Sep 15, 2005 | 11:09 PM
teamm_AP1's Avatar
Old Sep 16, 2005 | 02:22 PM
Ef Love's Avatar
i'm sure you can take it to a shop you know and they could probably help you.
Old Sep 17, 2005 | 11:27 AM
teamm_AP1's Avatar
Default Re: (Ef Love)
Thats what i was thinking.
Old Sep 21, 2005 | 11:21 AM
VRD^sam's Avatar
try a extension..
Old Sep 21, 2005 | 01:27 PM
jDm_eDm's Avatar
Default Re: (boosted_ef)
damm i got the same problem...and same lug nut..it came with the car and the freakin previous owner lost the key... brake masters can take it off for 40 bucks...but i rather try to find a better solution then paying 40 bucks... ill try the allen wrench thing tonight hope it works
Old Sep 21, 2005 | 05:56 PM
teamm_AP1's Avatar
Default Re: (eG_d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eG_d &raquo;</TD></TR><TR><TD CLASS="quote">damm i got the same problem...and same lug nut..it came with the car and the freakin previous owner lost the key... brake masters can take it off for 40 bucks...but i rather try to find a better solution then paying 40 bucks... ill try the allen wrench thing tonight hope it works</TD></TR></TABLE>
yeah i got an answer to this problem. went to a local tuner store and found out that gorilla makes the lug nut. it's not the typical hex key. gorilla makes 500 different types of keys and w/o the key number. it is nearly impossible to get a replica.
i tried a 3/8ths extension/allen wrench, no luck......
Old Jan 27, 2007 | 07:54 PM
Boricuanology's Avatar
Default Re: (teamm_AP1)
I think I have the same ones, what sucks is that I just did my whole braking system, new pads, rotors, ARP extended studs ect. I already did the rear and now I don't know where I put the 8 lug nuts with the key. So tomorow I will go to the garage and try to find it.
If I was you just go to any place that sells them, I just went to napa when I had this problem when I got my car. My car had some lug nuts, the ones that look like a allen key hole on them, the guy at napa just took one by one till he found the one that works and then he just sold me the key and order another key for the set.
Good luck man.
Old Jan 28, 2007 | 02:21 PM
eg64u's Avatar
yea inner splined blows
Old Feb 4, 2007 | 02:04 PM
91_civic_si's Avatar
Default Re: LUG NUT!!! HELP HELP.... (teamm_AP1)
well the best place to get something out like that would be like a tire place like les schwab or a simular place that does that..... and they will get it out for you..... people always come to my job and the same **** happens ti them mostly on vw lug nut keys they always strip we use an air tool like a gun and we hit it well its alittle more but find a place that sells tires and they will fix it for you it should be free if not then say you went in for a rotate and they lost your key that should work..........
Old Feb 4, 2007 | 02:10 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: LUG NUT!!! HELP HELP.... (91_civic_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91_civic_si &raquo;</TD></TR><TR><TD CLASS="quote">well the best place to get something out like that would be like a tire place like les schwab or a simular place that does that..... and they will get it out for you..... people always come to my job and the same **** happens ti them mostly on vw lug nut keys they always strip we use an air tool like a gun and we hit it well its alittle more but find a place that sells tires and they will fix it for you it should be free if not then say you went in for a rotate and they lost your key that should work..........</TD></TR></TABLE>
did you ever go to english class when you were in school because when you learn english you learn that you're supposed to put a capital letter at the start of every sentence and a period at the end of every sentence which will help other people understand what you're trying to say because it breaks what you're trying to say into individual sentences and thoughts which are easier to understand and if you don't do that it will just sound like a bunch of words thrown together that don't make a lot of sense as you can see from reading this
vtec770
Feb 15, 2007 05:04 PM
liem43
Nov 11, 2005 07:25 PM
billyhoe
May 18, 2005 02:23 PM
sjteg
Jul 13, 2003 06:39 PM
spencedogg
Nov 28, 2002 06:47 AM
