Turning it up, Alpine shuts off
hey well im having this problem with my car.. doesnt really bother me much but i just want to know whats up.. well yeh installed a new alpine deck in my car.. once i bump it up with my subs to about 23 volume .. my alpine shuts off and reloads again.. does any one know wassup?
thanks
thanks
Need more info, make/model of Alpine HU any amps and subs/ speakers, is the Alpine HUs internal amp running any speakers, or are you using an amp for them, or do you just have an amp for the subs, also when you say the Alpine "shuts off" do you mean, [and it sounds like it] it turns right off, [no power] and you loose all the presets and clock resets, the disk pops out when the power comes back on" also need to know how the HU is wired, powers and ground?
94
94
the HU is wired to the power from the car and the amp is for the subs.. the amp is wired directly to the battery and its just the HU that shuts off because its too loud.. all the other like the clock is still set
my alpine did that alot till I ran the 12v straight to the battery bc it wasn't getting enough power and it also tells u in the alpine manual to run it straight to the battery try that and see if it works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">is there another way?</TD></TR></TABLE> Yes....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superman137 »</TD></TR><TR><TD CLASS="quote">my alpine did that alot till I ran the 12v straight to the battery bc it wasn't getting enough power and it also tells u in the alpine manual to run it straight to the battery try that and see if it works</TD></TR></TABLE> It is the best way, just like your amp, run a fused 10ga or 12 ga wire from your batt. to behind the HU and connect the HUs constant power, [yellow] to it, don't forget to cap off the oem 12V+ constant wire you are no longer using, I would also add a 10ga or 12ga ground wire from the chassis of the HU to the cars chassis. [or ground point] as close to the HU as you can, [you can use the HUs back support bracket/strap mounting bolt to mount the ground to the HUs chassis.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neo_ »</TD></TR><TR><TD CLASS="quote">I had the SAME EXACT problem, turned out that I had a bad ground spot. </TD></TR></TABLE>Yea it can just as well be a poor ground, both power in, and ground "return" have to be just as good.
94
94
b18tdelsol
Audio / Security / Video
Jan 7, 2003 08:25 PM
94
