from s1 to ys1, but what clutch?
Old Sep 13, 2005 | 06:05 PM
DA6Iceman's Avatar
Default from s1 to ys1, but what clutch?
alrighty then.. hopefully someone who knows the answer to my problem reads this. my 3rd gear was blown on my ys1 trans so i swapped it out for a b16 s1. the s1 has been rebuilt but there was no clutch arm, fork or throughout bearing. so i swapped out the parts from the ls trans. I drove it for like a week to work and back and everything was fine til the other day when i put the clutch to the floor and the clutch wouldnt disengage. no matter what i did or how far I adjusted it , it never helped. Today when i got in it to pull it in the garage it worked fine, until i drove it around the block for a while and then it did it again. also the clutch feels stiff as hell and fully releases at half pedal. Now its back in the garage and I started to pull it back out, is the clutches different? or the throughout bearing? the car has 193K and im pretty sure the clutch has been in there a while, Hopefully someone can tell me somethin cause as of now im kinda clueless.. thanks guys.
Old Sep 13, 2005 | 06:23 PM
importdude2000's Avatar
the s1 uses a differnt clutch than a 92-93 ys1
u need to order a 90-91 integra clutch kit
Old Sep 13, 2005 | 06:48 PM
DA6Iceman's Avatar
Default Re: (importdude2000)
hrmmm... I wonder whats different though, because the splines are the same and like I said it worked fine, i wonder if the pressure plate is different... thanks man.
Haarstad
Jun 24, 2012 09:50 PM
danno33
Jul 14, 2009 07:45 AM
Street Racer X
Sep 21, 2008 02:35 PM
harmonator84
Transmission & Drivetrain
Aug 28, 2008 10:14 AM
X-Static
Nov 16, 2006 10:25 AM
