thermostat ground
Old Sep 13, 2005 | 04:01 PM
crxdriver89's Avatar
Default thermostat ground
are you supposed to have two grounds on your thermostat?? my brother and i were doing the sohc zc swap, and i wasn't there the whole time, but it wasn't running right and i checked it out, and sure enough, no groung wire on the thermostat. im thinking this could solve a lot of my problems. and i did search for grounds and engine grounds but nothing came up. you'd think that it would, but i didn't use the advanced search. also, where are the other grounds?? i know about the valve cover ground, but remind where the others are. thanks in advance fellas
Old Sep 13, 2005 | 04:36 PM
fourthgenhatchB17's Avatar
Default Re: thermostat ground (crxdriver89)
Yes there should be a few wires grounded at the thermostat housing. They are all connected together and ground at a single point. They should be easy to locate since they all come out of the engine harness where the t-stat housing is. If that ground is loose or missing, the car will run funny as hell. Other grounds are the valve cover one like u stated and one from the tranny to frame.
Old Sep 13, 2005 | 06:47 PM
USDM 4G VTEC's Avatar
theres 2 GNDs at the thermostat
they provide GND to the ecu,
they are important
make sure u got them clean and good
Old Sep 13, 2005 | 07:19 PM
Default Re: (USDM 4G VTEC)
well, that explains a lot. did you say the ground wires are running out of the engine harness?? im gonna go search for them right now
Old Sep 13, 2005 | 07:21 PM
Default Re: (crxdriver89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdriver89 &raquo;</TD></TR><TR><TD CLASS="quote">did you say the ground wires are running out of the engine harness?? </TD></TR></TABLE>
Yep. If they arent bolted to the t stat housing, they are probably dangling around near by.
Old Sep 13, 2005 | 08:40 PM
hey, i looked around in there with a flashlight, i have no dangling wires. you sure its like that on an hf wiring harness?? and if not, should i run the grounds to the same place the battery is grounded?? and it shouldn't matter which bolts on the housing i run the grounds from, should it?? thanks
Old Sep 13, 2005 | 09:00 PM
kulangot's Avatar
do you know were the thermostat is? there is a ground that go's on the top of it.
Old Sep 16, 2005 | 10:03 PM
Default Re: (kulangot)
yeah, i know where the thermostat is, and after moving some wires around, i did notice that there was one ground coming from the wiring harness attatched to the top. so i ran another ground and ran it to a bolt just in front of the battery, but it didn't make a difference, i still throw a code one, and i know the o2 sensor is good. should i have ran the other ground straight to the negative batt. terminal??man, if i can get this damn code 1 to go away, this motor will be running great, after a month of messin with it. sometimes i just wanna give up, ya know? but its like a black hole, it justs keeps sucking me back in, along with anything in my wallet.
Old Sep 17, 2005 | 07:44 AM
zccr-xsi's Avatar
tea man make sure that thrmo housing ground is good and clean or u will throw a code 20.
ferrabi
Nov 27, 2017 02:07 PM
ezcape
May 10, 2011 10:52 PM
hondaz6lx
Oct 4, 2007 04:14 PM
LSpimpTEC
Feb 11, 2005 09:16 AM
dingusjt
20
Mar 6, 2003 09:03 PM
