92 Prelude with H23 motor
Old Sep 13, 2005 | 03:09 PM
gsr984dr's Avatar
Default 92 Prelude with H23 motor
How easy would it be to make this car Vtec? If this is not possible, can anyone recommend the easiest way to make more power without going all out on a turbo or supercharger?
This will be a daily driver and would like to have more power that what it has.
Thanks.
Old Sep 13, 2005 | 03:12 PM
Lewdin' Incognito's Avatar
Default Re: 92 Prelude with H23 motor (gsr984dr)
1. Swap in H22 motor
-or-
2. Swap head with H22 head.
Some light reading for you:
https://honda-tech.com/zerothread?id=510617
It will really help
Old Sep 13, 2005 | 03:51 PM
AndyD's Avatar
If it will be your daily driver and you want more useable power, I would go for the G23 hybrid.
https://honda-tech.com/zerothread?id=1046336
That's what I would do if I wanted useable power in my daily driver.
Old Sep 13, 2005 | 04:44 PM
Dougs96SI's Avatar
Default Re: 92 Prelude with H23 motor (AndyD)
H23 Vtec's are rare, but are becoming more common as new light is shed on the durability of these builds.
Old Sep 13, 2005 | 05:03 PM
high_revs's Avatar
Default Re: 92 Prelude with H23 motor (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">H23 Vtec's are rare, but are becoming more common as new light is shed on the durability of these builds.</TD></TR></TABLE>
h23/vtec
you'll love it a lot more then a h22 trust me.
Old Sep 13, 2005 | 05:06 PM
Dougs96SI's Avatar
Default Re: 92 Prelude with H23 motor (all mOtor h23)
All Motor H23, are you running the G23 or did you just cam the H23?
Old Sep 13, 2005 | 05:08 PM
high_revs's Avatar
neither....h23/vtec with intake, header-tech header with stepped primaries, 3inch collector and 3" full exhaust....i try to keep it on the down low tho :-)...NJ thieves suck.
Old Sep 13, 2005 | 05:11 PM
Dougs96SI's Avatar
Default Re: (all mOtor h23)
Whats next on the list? Isnt the 3in exhaust a little over kill? Maybe planning ahead for a little boost?
Old Sep 13, 2005 | 05:13 PM
high_revs's Avatar
Default Re: (Dougs96SI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">Whats next on the list? Isnt the 3in exhaust a little over kill? Maybe planning ahead for a little boost? </TD></TR></TABLE>
nahh i dont think its overkill...next will be type s pistons, then some cams and a lot of headwork.
Old Sep 13, 2005 | 05:14 PM
Dougs96SI's Avatar
Sounds good, good luck with the build and keep us H23 owners informed.
Old Sep 13, 2005 | 05:17 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">Sounds good, good luck with the build and keep us H23 owners informed.</TD></TR></TABLE>
yeah no doubt.....i only rev it to about 7200 right now, and dont really feel the need for more since im stock cams and my compression is only 9.5:1 only because the h22 head has a bigger combustion chamber and the head is milled .010"...when all set and done i want to be pushing close to 250whp...but i doubt i will have the h23 bottom end by then...i'll be running close to a 2.5L by then.
Old Sep 13, 2005 | 06:18 PM
Dougs96SI's Avatar
What ecu are you running that allows your H23 to rev to 7200 rpms? Isnt the stock rev limiter at 7k?
Old Sep 13, 2005 | 06:27 PM
eMpAtHy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">What ecu are you running that allows your H23 to rev to 7200 rpms? Isnt the stock rev limiter at 7k?</TD></TR></TABLE>
my chipped ecu lets me hit 7.5
damnit, the ******* redline just popped out of my head :\ ill come back when i remember.
Old Sep 13, 2005 | 07:09 PM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI &raquo;</TD></TR><TR><TD CLASS="quote">What ecu are you running that allows your H23 to rev to 7200 rpms? Isnt the stock rev limiter at 7k?</TD></TR></TABLE>\
p28
dspinz9747
Mar 13, 2009 05:56 PM
bluelude92si
Aug 29, 2007 07:25 PM
ripperbone
Apr 2, 2006 05:02 PM
HRDCORD
12
Aug 13, 2003 05:56 PM
h22mark
Jul 4, 2003 05:48 PM
