ATTS light!
Old Sep 13, 2005 | 03:05 PM
Fobstylez's Avatar
Default ATTS light!
As I was driving to work today my check engine and ATTS light came on. I wasnt pushing the car nor slamming around corners. Car made it to work fine but it makes me uneasy. Whats wrong with it? Is there anyway to reset that? Is this something I can fix or do I have to go buy a new unit? any answers are better then none, thanks
Old Sep 13, 2005 | 05:42 PM
bubs's Avatar
That happens pretty regularly on my 97' SH. You can pull the code and find out what the exact problem is, but it's probably nothing major. You should be able to pull the radio/clock fuse for a minute or two under the hood to make it go off.
Old Sep 13, 2005 | 11:56 PM
Fobstylez's Avatar
Default Re: (bubs)
thanks a lot man, i'll try that in the morning tomorrow. How do I go about checking the code?
Old Sep 14, 2005 | 10:56 AM
red92si's Avatar
either use an OBD2 scantool, or jump the service connector behind the center console and read the codes off of the light.
Old Sep 17, 2005 | 12:58 PM
Fobstylez's Avatar
Default Re: (red92si)
thanks guys, i pulled the fuse and put it back. Lights are all gone so i assume everything is in the clear. If it comes up again then i would check up on this.
crxaddikt
10
Sep 13, 2014 11:47 AM
ericrcan
Nov 24, 2012 07:54 PM
Y2KGSR
Feb 16, 2009 12:00 PM
Iamcuddles
Dec 22, 2005 08:51 AM
