Check engine light
Old Nov 23, 2005 | 02:46 PM
Y2KGSR's Avatar
Default Check engine light
I was driving today and I was low on gas coming up a good size hill and it felt like it was running out of gas then the check engine light came on.......pulled over got gas and now it's running fine.........How do I turn the light off???????
Old Nov 23, 2005 | 02:51 PM
98IntegraLSNonVtec's Avatar
Default Re: Check engine light (Y2KGSR)
disconnect the battery..should work just if you have the stock radio make sure you have the security code also if you open up the hood of your car in the fuse panel box you can disconnect the fuse (i think) it is the one on the top left for a few seconds then put it back on...besides the check engine light shouldnt have turned on for that thats what the fuel light is for.
Old Nov 23, 2005 | 02:53 PM
Y2KGSR's Avatar
Default Re: Check engine light (98IntegraLSNonVtec)
cool...I'll try it Thanks
Old Nov 23, 2005 | 02:56 PM
No problem but if the light decides to turn on again you should ask someone with a scan tool to scan the codes and find out what might be wrong with it
Old Nov 23, 2005 | 02:59 PM
kchungb17a's Avatar
Auto Zone will let you use thier scan tool for free. You can check the code and reset it.
LoseRPunKx182's Avatar
how do u know that was the problem? i could get it read first
Old Nov 23, 2005 | 06:00 PM
eas156's Avatar
Default Re: Check engine light (LoseRPunKx182)
yeah checker will loan you a scan tool to read codes and reset the light
Old Nov 23, 2005 | 06:04 PM
GSR_96814's Avatar
Default Re: Check engine light (eas156)
Isn't there an easier way to reset the check engine light besides buying scanners or disconnecting fuses and battery? My friend did it for me in like a minute, its like a button you need to press underneath the dash. Anyone know what I'm talking about??
Old Nov 23, 2005 | 07:53 PM
Default Re: Check engine light (GSR_96814)
u can pull a fuse
Old Nov 23, 2005 | 07:58 PM
93_teg_CT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR_96814 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there an easier way to reset the check engine light besides buying scanners or disconnecting fuses and battery? My friend did it for me in like a minute, its like a button you need to press underneath the dash. Anyone know what I'm talking about?? </TD></TR></TABLE>
That's for when you change you oil...
Old Nov 23, 2005 | 08:58 PM
GSR_96814's Avatar
Default Re: Check engine light (93_teg_CT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93_teg_CT &raquo;</TD></TR><TR><TD CLASS="quote">
That's for when you change you oil...</TD></TR></TABLE>
Yeah I wasn't sure. The light came on and nothing was wrong with my car since I just changed my oil.
Old Nov 24, 2005 | 01:58 AM
denieone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eas156 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't there an easier way to reset the check engine light besides buying scanners or disconnecting fuses and battery? My friend did it for me in like a minute, its like a button you need to press underneath the dash. Anyone know what I'm talking about?? </TD></TR></TABLE>
thats the schedule maint reminder, just borrow a scan tool and find out what trigger you check engine light.
Old Feb 16, 2009 | 09:35 AM
d2r's Avatar
d2r
Autozone dont do obd1
Old Feb 16, 2009 | 10:00 AM
mrdeadman's Avatar
They let me pick
You don't need a damn scan tool.
https://honda-tech.com/forums/acura-integra-6/ecu-abs-codes-here-978933/
****in a people.
Old Feb 16, 2009 | 12:00 PM
paton5g's Avatar
Or you could just use the jumper on the passenger side and get the code yourself.
You can do it in your driveway, you don't have to go anywhere and hell you won't waste another persons time!
ericrcan
Nov 24, 2012 07:54 PM
Corruption
Jun 3, 2006 12:08 PM
acura0gsr0ntegra
Sep 15, 2003 09:49 AM
mkokwilson
Sep 17, 2002 04:22 PM
