JDM Fog Question
Old Sep 13, 2005 | 01:30 PM
illdiealonlyazn's Avatar
Default JDM Fog Question
And another thing. My alarm hooks into 2 of the plugs i need to put the fogs in. do i just take out the wires for the alarm and than splice it into the wire for the jdm fog ilghts? one of them makes the lights blink when i open/ lock my doors the otehr one is the one that makes the siren go off. jus splice it in?
Modified by illdiealonlyazn at 4:57 PM 9/13/2005
Modified by illdiealonlyazn at 10:22 AM 9/14/2005
Old Sep 13, 2005 | 08:22 PM
Default Re: JDM Fog Question (illdiealonlyazn)
bump
Old Sep 13, 2005 | 09:21 PM
mkazm83's Avatar
there is no "jdm" fog panel...the JDM fog button mounts next to the moonroof/cruise controls, just get the USDM panel for the us version of the fogs
Old Sep 13, 2005 | 09:47 PM
Default Re: JDM Fog Question (mkazm83)
Anyone have fogs and alarm? do the alarm wires just splice in w/ the fog wires?
Old Sep 14, 2005 | 10:09 PM
bump
Old Sep 15, 2005 | 03:33 AM
1epmugenlude's Avatar
leave the usdm panel in place. I mounted my jdm foglight switch where the dimmer switch for the interior lights was. If your talking of the interior fuse panel where the alarm is getting its power source it should be fine to splice the foglights there.
Old Sep 15, 2005 | 03:38 AM
maybe this will help?
http://www.hondaprelude.to/articles/install/jdmfogs.html
Old Sep 15, 2005 | 09:15 AM
prelude1897's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illdiealonlyazn &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have fogs and alarm? do the alarm wires just splice in w/ the fog wires?</TD></TR></TABLE>
No, you plug everything into the fuse panel behind the driverside kick panel. I have mine hooked up to where they flash when I turn on/off my alarm
Old Sep 15, 2005 | 12:04 PM
Default Re: JDM Fog Question (prelude1897)
I looked and my alarm wires go into those slots. so i just splice my alarm wires in w/ my fogs right?
Old Sep 15, 2005 | 02:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illdiealonlyazn &raquo;</TD></TR><TR><TD CLASS="quote">I looked and my alarm wires go into those slots. so i just splice my alarm wires in w/ my fogs right?</TD></TR></TABLE>
Are you sure about that? I've never seen an alarm that would hook into those slots
Old Sep 15, 2005 | 03:59 PM
Yes im very sure. one of them if i pull it out when i open and close the doors the lights dont blink anymore. the other one if i pull the alarm goes off.
Old Sep 15, 2005 | 07:45 PM
EGPrelude's Avatar
Yes you can just splice them together.
Some alarm shops tend to use these fuse panel slots with female spade connectors to connect aftermarket alarms.
One slot is for the constant +12V and the other probably for the parking lights. It is fine if you splice the fog wires and the alarm wires together. Just make sure you splice the correct wires there together.
Old Sep 16, 2005 | 04:07 AM
Default Re: (EGPrelude)
Hmmm, thats wierd...Go ahead and splice into the wires then, and you should be fine.
LSteggyguy
Audio / Security / Video
Sep 10, 2012 08:55 AM
dc2_916
Jan 4, 2010 09:35 AM
del sol1658
Oct 9, 2008 12:55 PM
Matgallis
Oct 1, 2003 05:13 PM
Matgallis
Sep 29, 2003 11:48 PM
