B&M short shifter question???
Old Sep 13, 2005 | 09:47 AM
EKtypeRhaTcH's Avatar
Default B&M short shifter question???
Will a B&M pro edge shifter made for a 92-00 civics fit on my 00 civic with a b series??? i checked the product number and its 45074 for both civic and integra. if anyone knows please let me know before i buy it. looking to buy it off another H-T member
Old Sep 13, 2005 | 09:49 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: B&M short shifter question??? (EKtypeRhaTcH)
According to my calculations, yes.
Old Sep 13, 2005 | 09:51 AM
hoffman4684's Avatar
I second that.
Old Sep 13, 2005 | 11:02 AM
resol's Avatar
Default Re: (hoffman4684)
if that same shifter you have worked in my 93 hatch with a gsr, then im pretty sure it would fit
Old Sep 13, 2005 | 11:50 AM
rmcdaniels's Avatar
I put one on my '99 Si and it works great.
Old Sep 13, 2005 | 12:34 PM
clint g's Avatar
Default Re: B&M short shifter question??? (rmcdaniels)
It works just fine
Old Sep 13, 2005 | 12:39 PM
Sijray21's Avatar
you should be fine
the only thing you might have to "modify" would be the width of the connecting rod to the shifter rod. It's not that hard to modify if you even need to do it - just stretch it out using pliers or compress it using some pliers or by simply tightening it till it's snug.
Old Sep 13, 2005 | 01:04 PM
rmcdaniels's Avatar
Default Re: B&M short shifter question??? (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">you should be fine
the only thing you might have to "modify" would be the width of the connecting rod to the shifter rod. It's not that hard to modify if you even need to do it - just stretch it out using pliers or compress it using some pliers or by simply tightening it till it's snug. </TD></TR></TABLE>
Mine came with a couple of sets of nylon bushings to make it fit, I used the set that fit my car, I'm guessing the other set is for other years/models.
Old Sep 13, 2005 | 02:08 PM
thanks for the input everyone does anyone have pics of it installed? (from underneath)
Old Sep 13, 2005 | 02:46 PM
cute little bastard
Default Re: (EKtypeRhaTcH)
Goddamn, gotta make the FAQ thread like 10 times bigger font than the other threads.
https://honda-tech.com/zerothread?id=1007935
highrpm666
Dec 29, 2010 05:28 PM
Muffler Bearing
Apr 20, 2007 01:03 PM
mraza
18
Apr 10, 2007 08:53 AM
krisjk2
Aug 16, 2005 05:52 PM
hcivic99
11
Jan 2, 2005 08:47 PM
