B&M short shifter question???
Will a B&M pro edge shifter made for a 92-00 civics fit on my 00 civic with a b series??? i checked the product number and its 45074 for both civic and integra. if anyone knows please let me know before i buy it. looking to buy it off another H-T member
Re: B&M short shifter question??? (EKtypeRhaTcH)
you should be fine
the only thing you might have to "modify" would be the width of the connecting rod to the shifter rod. It's not that hard to modify if you even need to do it - just stretch it out using pliers or compress it using some pliers or by simply tightening it till it's snug.
Re: B&M short shifter question??? (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 »</TD></TR><TR><TD CLASS="quote">you should be fine
the only thing you might have to "modify" would be the width of the connecting rod to the shifter rod. It's not that hard to modify if you even need to do it - just stretch it out using pliers or compress it using some pliers or by simply tightening it till it's snug. </TD></TR></TABLE>
Mine came with a couple of sets of nylon bushings to make it fit, I used the set that fit my car, I'm guessing the other set is for other years/models.
cute little bastard
Re: (EKtypeRhaTcH)
Goddamn, gotta make the FAQ thread like 10 times bigger font than the other threads.
https://honda-tech.com/zerothread?id=1007935
