yet another ;) my first down pipe and exhaust.....
what do you guys think? some of my welds turned out pretty good, actually, i noticed every weld i did got better. it's a lot easier to weld pipe to pipe than it is to weld pipe to flange i found out. this is mostly just a couple hours on the welder and reading all of the tips you guys give in here to other beginners, i can honestly say a lot of things i read in this forum helped a lot! i still need to finish the axle back section and finish a couple of the welds, but all in all, i'm very happy. this was with a flux core miller 135.
midsection with v band connection for dp
the down pipe
oh ****, resizing right now
the down pipe
lincoln and miller merged companies?
lol.
i would get gas, and stop the use of the flux core. its honestly just easier to use. looks better, and is more consistent.
good first project though
lol.i would get gas, and stop the use of the flux core. its honestly just easier to use. looks better, and is more consistent.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">lincoln and miller merged companies?
lol.
good first project though</TD></TR></TABLE>
lol, my bad, lincoln. i borrowed it from a buddy, but yeah, when i buy one, it will have gas for sure. you gotta take what you can get
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowhonda88 »</TD></TR><TR><TD CLASS="quote">that WG merge is mighty close to your turbine outlet. May cause boost creep, then again, some people do it like that and have no problems
it only looks like that.. its open dump. look in the first few pics and you can see the dumptube dumping down by the oil pan
</TD></TR></TABLE>it only looks like that.. its open dump. look in the first few pics and you can see the dumptube dumping down by the oil pan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junkyard racer »</TD></TR><TR><TD CLASS="quote">someone said your car is slow as ****.
it is, this stuff's just for looks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeshlude »</TD></TR><TR><TD CLASS="quote">Is that stainless or mild???</TD></TR></TABLE>
14 gauge mild<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowhonda88 »</TD></TR><TR><TD CLASS="quote">that WG merge is mighty close to your turbine outlet. May cause boost creep, then again, some people do it like that and have no problems </TD></TR></TABLE>
yeah, like someone else already said, it's open dump, the dump tube curves around the back of the dp
i tried welding piping for practice but i was getting too much burnthrough. So i stopped the hopes of making my own exhaust for my integra.
I was using a migwelder... is that not right for exhaust piping? If its ok to use maybe i just need to practice more. I had it set correctly i thought.
