will adjusting koni+GC affect spring rates?
Hi,
Since the bottom part of the koni shock can't really be adjusted except with those preset locations of the cir clips, when you raise/lower the car using the coilovers, the spring rate will change right? like if you raise the car, the springs will be compressed more and if you lower the car, the springs will be less compressed.
Is that even an issue? since no one seems to talk about that, I guess it's not really important or is it?
thanks,
thanks,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyDC2 »</TD></TR><TR><TD CLASS="quote">oh and i thinkin those kind setup's dont have preload setp. only for full suspenstion i believe.</TD></TR></TABLE>
Dude................... wow. Just dont come back.
