Exhaust Diameter - Is it the inner or outer diameter ?
Old Sep 12, 2005 | 07:56 PM
schumi's Avatar
Default Exhaust Diameter - Is it the inner or outer diameter ?
Searchewd but couldn't find anything...may this is a stupid question!!!!
When talking about exhaust Diameter, what is considered? Iinner or outer diameter ?
If its the inner diameter, then a 2.5" exhaust should have 2.5" between the inner walls of the pipe?
thanks a lot for answering the silly question
Old Sep 12, 2005 | 09:09 PM
TODA GS_R's Avatar
if youre talkin bout piping...its usually outside diameter. inside diam. is uaually with univ. muffler inlets and...da da da
Old Sep 12, 2005 | 10:06 PM
schumi's Avatar
Default Re: (TODA GS_R)
I was talking about CAT back systems...for example when someone says, its 2.5" mandrel bent CAT back system, what does that mean as far as diameter is concerned?
thx
Old Sep 12, 2005 | 10:25 PM
LSvtec03's Avatar
Default Re: (schumi)
outer diameter.
Old Sep 12, 2005 | 10:32 PM
LSD Motorsports's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schumi &raquo;</TD></TR><TR><TD CLASS="quote">I was talking about CAT back systems...for example when someone says, its 2.5" mandrel bent CAT back system, what does that mean as far as diameter is concerned?
thx</TD></TR></TABLE>
Piping is always measure in o.d
tubing is always measured in i.d
Catback exhaust systems would be measured in o.d as they are piping. However The wall thickness is not very much, the i.d would still be around 2.3 or so.
Old Sep 12, 2005 | 10:36 PM
turboDeznutz's Avatar
Default Re: (LSD Motorsports)
thats good to know thanks...lsd
Old Sep 12, 2005 | 11:37 PM
TODA GS_R's Avatar
there is no diff in tubes and pipes.
Old Sep 13, 2005 | 12:11 AM
lol, ok
Old Sep 13, 2005 | 12:28 AM
TODA GS_R's Avatar
im not trying to clown or nothin...
Old Sep 13, 2005 | 07:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODA GS_R &raquo;</TD></TR><TR><TD CLASS="quote">im not trying to clown or nothin...</TD></TR></TABLE>
I know, well maybe im the one whos been fooled all these years in the industry, but when i purchase piping and tubing from all my distributors, theyve always said thats the difference. Thats how you distinguish the two.
Old Sep 13, 2005 | 10:46 AM
schumi's Avatar
This is interesting!!!!!!
Can some one post the Outer diameter of any so called 2.5" CAT back system?
I guess, it would show whether, the manufacture refers to OD or ID!!!!!
I am also going to look at the stock OD this evening
thx
Old Sep 13, 2005 | 11:10 AM
2G0S0R1's Avatar
New User
Companies refer to Outer 99% of the time. If you have a "2.5" Catback" it will most likely be ~2.36" ID if the piping is the average 1/16th inch thickness. Some exhausts are heavier/thicker and will drop you down to a 2.25" ID.
Old Sep 13, 2005 | 09:16 PM
Default Re: (2G0S0R1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2G0S0R1 &raquo;</TD></TR><TR><TD CLASS="quote">Companies refer to Outer 99% of the time. If you have a "2.5" Catback" it will most likely be ~2.36" ID if the piping is the average 1/16th inch thickness. Some exhausts are heavier/thicker and will drop you down to a 2.25" ID.</TD></TR></TABLE>
Thats exactly what i was saying, only it should be 100% of the time for exhaust systems.
Old Sep 13, 2005 | 09:35 PM
TODA GS_R's Avatar
its all good...i work at a muffler shop thats why...majority of the time...the aftermarket catbacks are stainless and very thin (gauge) and thats why i preferr aluminized steel which is way thicker and durable (good if your cars dropped like mines)
Old Sep 13, 2005 | 09:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TODA GS_R &raquo;</TD></TR><TR><TD CLASS="quote">its all good...i work at a muffler shop thats why...majority of the time...the aftermarket catbacks are stainless and very thin (gauge) and thats why i preferr aluminized steel which is way thicker and durable (good if your cars dropped like mines)</TD></TR></TABLE>
This is usually the case for the sake of cost. Thats also why we usually build custom exhaust systems for out customers.
Old Sep 14, 2005 | 03:36 AM
.:JEROME:.'s Avatar
Default Re: Exhaust Diameter - Is it the inner or outer diameter ? (schumi)
I just ordered a full stainless 2.5" turbo downpipe from an undisclosed source and I measured it and the 2.5" advertised is inner diameter. It is like 2.70" - 2.75" outer diameter. Sorry I am not more accurate I have a shitty micrometer.
Old Sep 14, 2005 | 06:35 AM
Default Re: Exhaust Diameter - Is it the inner or outer diameter ? (.:JEROME:.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .:JEROME:. &raquo;</TD></TR><TR><TD CLASS="quote">I just ordered a full stainless 2.5" turbo downpipe from an undisclosed source and I measured it and the 2.5" advertised is inner diameter. It is like 2.70" - 2.75" outer diameter. Sorry I am not more accurate I have a shitty micrometer.</TD></TR></TABLE>
Im lost, why is the source undisclosed? Are they not legit or something?
pchan
Dec 15, 2007 02:10 PM
Prelude91siT
Feb 11, 2004 02:28 PM
4thgenlude
Dec 27, 2003 09:23 AM
ridnmyhonda
Dec 15, 2002 12:39 PM
