4WS steering wheel adjustment (need a guru).
I'll try to describe what I'm asking the best I can.
The service manual describes the adjustment of the front steering sensor so that the yellow paint mark points downward to show neutral (after removing the steering wheel). It says to use the steering wheel to do this. Does this also turn the steering shaft and the front wheels? Or can the front sensor yellow mark be adjusted seperate from the steering shaft?
