Hi-flow oil pump effect vtec?
Old Sep 12, 2005 | 07:25 PM
JDMKid71's Avatar
Default Hi-flow oil pump effect vtec?
I know that the vtec silonoid is activated with the oil presure, i beleive. however i was thinking about buying an aftermarket hi-flow oil pump from KMS (honda-performance.com) and was wondering if that would effect when the vtec kicks in, some quick answers would be nice, and i am searching right now on this. thanks.
Old Sep 12, 2005 | 07:56 PM
JDMKid71's Avatar
Default Re: Hi-flow oil pump effect vtec? (JDMKid71)
up
Old Sep 12, 2005 | 08:17 PM
turbotime's Avatar
i believe vtec kicks in at a certain oil pressure- if a high flow oil pump would increase oil pressure at a lower rpm then i would *assume* vtec would kickin at a lower rpm.
Of course you would prolly still need an rpm-activated switch to cause it to crossover at a lower rpm but perhaps with a hiflow oil pump it wouldnt be as bad for the engine as it is without (yes i know lowering the crossover is bad w/o highflo)
this is all speculation on my part tho
Old Sep 14, 2005 | 07:27 PM
JDMKid71's Avatar
Default Re: (turbotime)
Right.. thats kinda what i was thinking.. anyone else..? anyone actualy put in a hiflow oil pump with vtec...? does it effect when the vtec kicks in? thank you again.
Old Sep 14, 2005 | 08:18 PM
ROK801's Avatar
Default Re: (JDMKid71)
vtec kicks in off of oil pressure + the ecu tells it when it reaches a certain rpm(i believe 5500) to change over to vtec...
so id imagine if you did it and didnt throw a cel, youre straight...
youd be better off with a VAFC...
Old Sep 14, 2005 | 08:22 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: (ROK801)
The solenoid actuates VTEC, so your all good.
blues2k3
Dec 9, 2005 09:53 AM
H22T94
Jul 17, 2004 05:37 PM
hatch4raceb16
Aug 10, 2003 08:22 AM
thehondaguru
Dec 31, 2002 03:23 AM
