where/ what is my throttle plate? (notchy gas pedal)
Old Sep 12, 2005 | 07:18 PM
rolledthatho's Avatar
Default where/ what is my throttle plate? (notchy gas pedal)
hey guys i have a very notchy gas pedal its hurting my gas mileage etc.. i was told to clean the plate, with some cleaner and a wire brush etc... what exactly is the piece i am supposed to take off and clean?
does anyone have a picture
Old Sep 12, 2005 | 07:59 PM
bump
Old Sep 12, 2005 | 10:37 PM
Malgerus's Avatar
Default Re: (rolledthatho)
Take off your air intake. You should see the throttle plate on the inside of the throttle body.
Another reason for a sticky throttle could be that your stopper isn't adjusted correctly. Basically how it works is the throttle plate snaps shut against the stopper. There should be an adjustment nut below the throttle plate. HTH.
Old Sep 13, 2005 | 12:05 AM
markdman's Avatar
can you please explain "notchy" a little better?
things to inspect: throttle cable and where its attatched to your pedal, and the throttlebody rotor. if there is enough gunk inside the throttlebody to make your butterfly stick, something is VERY wrong.
Old Sep 13, 2005 | 03:48 AM
https://honda-tech.com/zerothread?id=1365962
the reply by SHBROWN is what im asking about...
Old Sep 13, 2005 | 07:04 PM
Old Sep 15, 2005 | 12:34 PM
bump
Old Sep 15, 2005 | 01:02 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Nylon bristle brush..don't use a wire brush...
Open the throttle wide open and clean not only the bore but also the
plate or "butterfly" itself, Especially around the edges..
85crx509
Sep 3, 2008 11:10 AM
ForceXVII
Dec 19, 2005 11:07 AM
nc_mx_kid
Dec 28, 2004 06:08 PM
93H22ACX
Jan 17, 2003 07:28 PM
93H22ACX
Jan 17, 2003 09:50 AM
