Throttle Plate
Old Jan 17, 2003 | 07:24 AM
93H22ACX's Avatar
Default Throttle Plate
I don't know why, but sometimes my throttle gets stuck and it is hard.....meaning when i give it a little gas it won't rev or go, so i have to gas it with more force for it to rev up and go again. anyone know why my throttle is like this?
Old Jan 17, 2003 | 09:38 AM
JT's Avatar
JT
Default Re: Throttle Plate (95PRELUDEVTEC206)
I would make sure the throttle plate area is not gunk up. Use carb cleaner if necessary. Then inspect the throttle cam stopper set screw, and adjust if necessary. Only adjust to the point the plate is not sticking. However, if you have to make adjustment to the stopper set screw, you will need to re-adjust the TPS sensor as well, as the change of throttle plate position will throw the TPS setting off.
Old Jan 17, 2003 | 09:50 AM
93H22ACX's Avatar
Default Re: Throttle Plate (JT)
there was no adjustment on the throttle body. The only thing is is that i have a weapon R throttle rotor. I had it for a while, but since my motor has been out for 3 months, it is kind of sticky.
tarpus91
Engine Management and Tuning
Apr 15, 2017 04:19 PM
return_2020
Jul 21, 2006 11:22 AM
clutcher
Apr 21, 2005 05:25 PM
1QWKGS
Apr 3, 2005 11:52 PM
93H22ACX
Jan 17, 2003 07:28 PM
