HELP ME HONDA TECH!!!!!
Old Sep 12, 2005 | 03:46 PM
impr323's Avatar
Default HELP ME HONDA TECH!!!!!
O.K here's the deal, I was driving today and I heard a strange noise coming from under the hood, so I checked it out. The crank pulley was moving back and forth like crazy so I shut the engine off and checked the bolt. The thing was spinning by hand, so I tightened it up an cranked her up for a few seconds,shut it off, and checked again. This time when I went to see if the bolt was still loose, half the damn bolt fell off!!! Well I needed to get home so I continued driving and sure as ****, the pulley comes off and my belts self destruct (not the timing). So long story short, half the bolt is in my crankshaft still!!! I have no idea what could have caused it and if its repairable or not. This is my only vehicle and i'm in the military so this is totally inconvenient. I know that the torque on that bolt is ungodly so do you guys think I could take it to a shop and have them remove it??? Also does anyone have or know where I can get another one of these bolts (don't say junkyard, I live in Sticksville)??? Please help me out!!!
Old Sep 12, 2005 | 03:56 PM
krc3104's Avatar
Default Re: HELP ME HONDA TECH!!!!! (impr323)
I had to get one at the junkyard when one came off on me. You could always go to majestichonda.com and order it, but it will take a bit. If this is like my Accord, I have a feeling the keystock broke. There is a keyway in there that a small piece of keystock goes in to keep the crank and pulley aligned. If this broke, hopefully it didn't whittle the keyway out. If it did, you gotta get a new crank. Sorry bro
Old Sep 12, 2005 | 04:19 PM
impr323's Avatar
Default Re: HELP ME HONDA TECH!!!!! (krc3104)
When you say keystock you mean on the crank or the pulley???? Cause the pulley is toast too.
Old Sep 12, 2005 | 04:25 PM
krc3104's Avatar
The keystock is the metal piece that goes into the keyway.
The crank will have a notch, and the pulley will have a notch. These will match up and the keystock will go into this notch, or groove (keeps the pulley from spinning the bolt off. There are many reasons that this happens, but usually it is because the bolt wasn't seated correctly. If the groove is messed up on the crank, you need a new one. It will cost more to get it fixed and balanced, etc... than to get a new one and have it installed. If you are lucky, like I was, just the pully will be messed up (or nothing, but very unlikely).
Old Sep 12, 2005 | 04:47 PM
impr323's Avatar
anyone else?????
Old Sep 12, 2005 | 04:48 PM
impr323's Avatar
anyone else???
Old Sep 12, 2005 | 05:12 PM
impr323's Avatar
If anyone else has any reccomendations or advice I will be greatly appreciative..
Old Sep 12, 2005 | 05:34 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Most likely easy outs will not work in this case so if you can't get enough gip on the remains of the bolt a shop would be your best bet. Make sure to charge that battery and don't use your directionals on the way. This isn't a bolt you will be able to find at a hardware store. Honda/Acura dealer or a junkyard are your only options, sorry to be the bearer of bad news..
Old Sep 12, 2005 | 05:37 PM
mike93eh
Guest
Posts: n/a
if the head of bolt has come off then the torque is no longer there. broken piece thats still in there should be loose. you can get some bolt extractors from sears or auto parts store and get the broken piece out and just get a new crank pulley and bolt.
Old Sep 12, 2005 | 05:49 PM
Default Re: (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh &raquo;</TD></TR><TR><TD CLASS="quote">if the head of bolt has come off then the torque is no longer there. broken piece thats still in there should be loose. you can get some bolt extractors from sears or auto parts store and get the broken piece out and just get a new crank pulley and bolt.</TD></TR></TABLE>Da I get a for not thinking, no mating surface, no torque.
Old Sep 13, 2005 | 02:22 PM
impr323's Avatar
Default Re: (HondaFanatic708)
Won't the crank turn if I try to take the stud out? How could I keep it from spinning without the pulley installed??
Old Sep 13, 2005 | 03:12 PM
mike93eh
Guest
Posts: n/a
Default Re: (impr323)
what i do is take the flywheel cover off and stick a big screwdriver in there. done it a million times...
Old Sep 13, 2005 | 03:13 PM
impr323's Avatar
I have to drop the tranny???
Old Sep 13, 2005 | 03:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impr323 &raquo;</TD></TR><TR><TD CLASS="quote">I have to drop the tranny???</TD></TR></TABLE>No just remove the inspection cover. You'll be able to access the ring gear on the flywheel from there..
Old Sep 17, 2005 | 01:30 PM
impr323's Avatar
Got that bitch out!!!! Took me 2 drill bits, an EZ out, and about 15 minutes. Came out pretty easy though. Now I have to wait for the new bolt I ordered and hope that the crank aint crossthreaded!!!
john676
Nov 17, 2015 09:15 PM
California98Civ
Aug 6, 2014 06:00 PM
MUGEN_EG95
Dec 10, 2008 03:58 PM
Johnny Groovez
Sep 14, 2006 10:50 PM
JDMKid71
Mar 20, 2005 11:46 AM
