burning a quart of oil a day?
Old Sep 12, 2005 | 12:49 PM
vtec-adykt's Avatar
Default burning a quart of oil a day?
i have a 89 crx dx with stock motor (d15b2). it needed a new head when i bought it, so i came across a used head and installed it along with new head gasket, water pump, timing belt, crankshaft seal, valve cover gasket kit, new oil and coolant. i've got it running and ive kept a real good eye on my oil level. which seems to go down everyday. I drive about 80 miles a day, and i can literally put a quart of oil in daily to keep it up to the max level. What could be the problem?
Old Sep 12, 2005 | 01:28 PM
91whiteZCrex's Avatar
Default Re: burning a quart of oil a day? (vtec-adykt)
does it puff smoke? or does it just leak?? leaving a puddle?
check your oil pan bolts/ gasket.
compressioin test
that should give you some idea or narrow it down at least
also valve seals
Old Sep 12, 2005 | 01:38 PM
Suck my DX's Avatar
Default Re: burning a quart of oil a day? (91whiteZCrex)
no way valve seals will cause u to lose a quart a day... that is a substantial amount of oil...if it is leaking, trace where the leak is coming from and fix it...and if it smoking, it will be bluish smoke..that is caused by ur rings going bad and it will need to be rebuilt
Old Sep 12, 2005 | 01:44 PM
crix351c's Avatar
Default Re: burning a quart of oil a day? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">no way valve seals will cause u to lose a quart a day... that is a substantial amount of oil...if it is leaking, trace where the leak is coming from and fix it...and if it smoking, it will be bluish smoke..that is caused by ur rings going bad and it will need to be rebuilt</TD></TR></TABLE>
Um yes it could...and yes that is alot of oil....he said he bought the head used...what if the moron broke the timing belt and kissed the valves and bent them...since this guys puts it on and wears down the seals .....therefore leaking oil ino all four cylinders......80 miles a day...its possible......By the way stranger things have happened
Old Sep 12, 2005 | 01:46 PM
Suck my DX's Avatar
Default Re: burning a quart of oil a day? (crix351c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix351c &raquo;</TD></TR><TR><TD CLASS="quote">
it COULD happen...but its so unlikely that i laughed when i read it
were gonna need more input from the owner to correctly answer this question
Old Sep 12, 2005 | 03:37 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec-adykt &raquo;</TD></TR><TR><TD CLASS="quote">. it needed a new head when i bought it, </TD></TR></TABLE>
What was wrong with the old head? Was the engine overheated?
Old Sep 12, 2005 | 04:24 PM
dravesef's Avatar
friend had the same problem with his b 16 did you replace the dowel pins that keep the head in the right place if not i would check that out
Old Sep 16, 2005 | 05:19 AM
vtec-adykt's Avatar
Default Re: (dravesef)
if i rev it up tp six grand, you would think someone was white smokin their tires. its a LOT of smoke. but it smells like gas.
Old Sep 16, 2005 | 06:49 AM
KansasKev's Avatar
Default Re: (vtec-adykt)
Yep this is <U>exactly</U> what my dx is doing. I am currently looking to do a d16b swap, but need to do a lot more research, first.
Old Sep 16, 2005 | 07:56 AM
vtec-adykt's Avatar
Default Re: (KansasKev)
you dont have an idea what it is, do you?
Old Sep 16, 2005 | 07:59 AM
vtec-adykt's Avatar
the old head had a broken camshaft. it broke off at the cam gear, with a small piece of shaft still attached to the gear. some people that knew the guy tell me that the car was smokin before he snapped the cam.
that1kidjr
Jun 15, 2011 03:56 PM
Rickdogg
Oct 11, 2010 10:09 AM
sawedoffcoupe
Apr 7, 2008 04:02 PM
BigC-ivic
Aug 27, 2005 07:53 AM
michaelpr
Jan 13, 2003 06:23 PM
