car will not start
ok my car will not start....i move the battery in the back and when the car was on it fall over a sparked and turned the car off now the car will not start unless u push start it...........well i was woundering how can i fix it......i was think of doing a push button start but i am not sure how to do that.....well thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_Si-R »</TD></TR><TR><TD CLASS="quote">you might have fried the main relay. you have almost the same motor setup as i do.</TD></TR></TABLE>
I thought the Mail Relay will keep the ECU from getting power,
if thats the case, push starting the car wont work.
No power to ECU, no firing of the injectors.
i dont know about the injectors, if the realy IS GOING bad then you still get power to the ecu, i know ive lookd at it. and push starting will work. what you do since you have an hf...lightest model...push or get someone to push then when you think you have enough speed let go then push the clutch in as fast as you can. keep in mind the the whole time you do this the car must me in the ON postion. pm me if you have more questions.
well i checked the fuse and that is not the problum they are all good........the car gets power and everything it will just not crank there is a clicking sound and the ecu turns on but no starting
yeah, sounds like its at your battery. check the connections on the terminals, wiggle em around and clean em up if dirty. try jumpstarting it. gotta be at the battery, mine did that and thats what it was
the alt will not keep it from starting... its either your starter or a fuse... i doubt its your battery considering that you get power to everything else... if you dont believe me then switch batteries with a known good one and see if that helps... you might also want to check all your connections like at the starter and what not
-Josh
-Josh
Well if you can roll start your car, that narrows it down to starting factors. That involves the battery, starter, ignition fuse, and any other possible fuses under the hood.
I was wiring up my push button ignition a while ago and sparked something. finished the install and went to start the car. Got ignition lights, but no action when I tried to start. Fried the ignition fusible link.
si90rex
Jun 24, 2007 05:53 PM
SiRkid
Oct 20, 2005 08:56 PM
