weird rpm drop
sometimes when i start my car and drive away my rpm starts like almost popping and it makes it so my car almost dies but i have to rev the engine and it goes away any ideaS? i already tried the fuel injector cleaner
Don't just start the car and drive away - let the oil start to heat........and let the o2 sensor heat a little bit - THUS, Letting the car "WARM UP"........you know.........
If you just start it up and go, your oil pressure will not be as high because itl'l be thick-like. Just let it run for a bit, and then drive away. And report back to us.
Sounds to me like fuel pump, fuel filter, fuel something.
Let your car idle to warmup temp, about 5-10 minutes, the fan will kick on. Watch the idle rpm's and let me know if they "jump around" or surge up and down.
If idle rpm is smooth, then it won't be a problem with air-intake, it'll be likely with fuel-intake.
susuking
Honda Civic (2001 - 2005)
Mar 18, 2007 08:40 AM
