Front disk Integra swap Issues
Old Sep 12, 2005 | 05:49 AM
2point3h22lude's Avatar
Default Front disk Integra swap Issues
I swapped out my EG front disk brakes with a 92-95 Integra front disk brake (with the knuckle), thinking that it will fit right in just like the rear, without any issues. Well I learned the hard way that the toe adjustment is thrown off big time (toe in like a motha), the camber adjustment went significantly negative (the top of the wheel is in, you can tell it from a 45 angle and from the front), and my tires now rub in the inside of the wheel well when I turn all the way to the right/left.
I was able to fix the toe problem, but I know that there is no camber adjustment on Honda's, which brings up my question. How can I correct this? Can I just get an upper suspension arm from an Integra, or do I have to purchase an adjustable upper arm? If you have any experience or knowledge on how to do this, please don't hesitate to respond. Thanks.
Old Sep 12, 2005 | 02:22 PM
Default Re: Front disk Integra swap Issues (2point3h22lude)
bump for the latecomers
Old Sep 13, 2005 | 08:50 AM
Please someone put some input. It would be cheaper to get a used integra upper arm, than an adjustable one. Anybody?
Old Sep 13, 2005 | 08:54 AM
SkoundrelUSA's Avatar
cute little bastard
Toe problem = get an alignment
Camber problem = camber kit (ie skunk, ingalls, omni)
Old Sep 13, 2005 | 08:59 AM
DjGuamstyles's Avatar
Default Re: Front disk Integra swap Issues (SkoundrelUSA)
Most people swap over the entire thing, so try to go look for the integra upper arm, it shouldn't matter though. hehe just a thought, did U put it on opposite sides?
Old Sep 13, 2005 | 10:14 AM
Default Re: Front disk Integra swap Issues (DjGuamstyles)
Thanks for your input, yeah I didn't know any better. I should have bought it with the upper arm, lesson learned for those who are planning to make the swap. I believed the guy that sold me the brakes when he said that it was a complete swap. I was wondering why it was so cheap ($65 shipped for the pair). I'm sure installed it on the correct side, I don't think it will fit the other way.
Old Sep 13, 2005 | 01:55 PM
Mista Bone's Avatar
D Tranny Guru
did you use a 92-93 or 94+ Teg knuckles?
I bolted on 96 Teg LS knuckles and brakes on the front, didn't need aligned.
Old Sep 13, 2005 | 02:29 PM
Default Re: (Mista Bone)
Ehh, I think they are the same
Old Sep 13, 2005 | 02:32 PM
pdiggitydogg's Avatar
Im pretty sure the da front arms are different than dc
fastblacks2k
Oct 7, 2007 09:40 PM
Slammd Sol
Jul 30, 2007 12:07 PM
UrbanEh
Feb 1, 2007 03:35 AM
UrbanEh
Suspension & Brakes
Feb 1, 2007 03:34 AM
racekar
Suspension & Brakes
22
Feb 2, 2005 05:46 AM
