b18b crank into b20a block
Old Sep 11, 2005 | 11:12 PM
rough_draft's Avatar
Default b18b crank into b20a block
will this work? I want to build a b20vtec, i have a b20a block and a b18b one. Since the b20a block has the crappy crank, can i use the b18b crank into the b20a and use the b20a pistons and rods jsut like a regular b20b or b20z? what will my compression be? thanks
Old Sep 11, 2005 | 11:14 PM
92TypeR's Avatar
FSAE
Default Re: b18b crank into b20a block (rough_draft)
As far as I know, the cranks and rods are identical.
Old Sep 11, 2005 | 11:17 PM
awesome, so would this work if i took the b18b ls crank, the ls rods, and then the stock b20a pistons? Then assemble it properly with the vtec head and it will be just liek any other b20vtec? am i missing anything? thanks
Old Sep 11, 2005 | 11:40 PM
realfasthonda's Avatar
Default Re: (rough_draft)
correct
Old Sep 12, 2005 | 02:43 AM
awesome. Are b20a rods the same as b20b rods?
Old Sep 12, 2005 | 05:26 AM
RudeBwaiSi's Avatar
Yes, as are B20Z. Change rod bolts.
Old Sep 13, 2005 | 12:50 PM
fmrprojects's Avatar
I believe the B20a came from the 88-91 Prelude. those blocks are different
Old Sep 13, 2005 | 06:24 PM
HondaCivicSiR1's Avatar
Default Re: (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects &raquo;</TD></TR><TR><TD CLASS="quote">I believe the B20a came from the 88-91 Prelude. those blocks are different</TD></TR></TABLE>yea that is what i thought also.anyone else know?
Old Sep 13, 2005 | 07:29 PM
Pinho's Avatar
well what i head also worked was a B21A5 from a 90-91 prelude crank and it bumps up from a 2.0l to a 2.2l its a little bit of work and its worth it and its supposibly makes some good power and torque..............
(still waiting on some info)
Old Sep 13, 2005 | 09:33 PM
RudeBwaiSi's Avatar
Yeah you right, A3 and A5.
nyceli
Mar 11, 2009 09:32 AM
eg4life1202
Jan 11, 2007 04:54 AM
konidude
12
Sep 2, 2005 04:46 AM
Si Shane
May 7, 2005 03:11 AM
Samurai
Nov 8, 2004 02:25 PM
