Quick question - Difference between b18a and b18b.
What is the difference in rods for the two motors? IS there?
I have rods for a b18a, but the crank is **** on the block. Can i use the internals in a b18b block w/ a b18b crank. Thanks in advance!
Modified by Si Shane at 2:51 PM 5/5/2005
b18a=g2 RS,LS,GS integra
b18b=g3 RS,LS,GS integra
same internals but i think the comp ration on the b18b's pistons are a little higher..
correct me if im wrong
they have the same rods
there is no differance between the blocks
the only different between the 2 motors are the heads and the cams and im is a lil different
a b20 block is also exactely the same except for the 84mm bore and pistons
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude »</TD></TR><TR><TD CLASS="quote">are the cranks any different?</TD></TR></TABLE>
no!!!
the blocks are 100% the same
no!!!
