grr... front end smacked the ground... speedbump!
Old Sep 11, 2005 | 08:50 PM
ekcivic9's Avatar
Default grr... front end smacked the ground... speedbump!
hello ht'ers...
so today i was getting out of the mall like i always do. im driving at about 30mph, and i always go over this speedbump at this speed. however, today as i go over the speedbump i hear a loud THWACK! and my front end proceeds to slam towards the ground.
now im kinda worried, could i have possibly damaged anything? i kinda went down to check, but it was too dark to see anything. i know theres a big plastic thing to prevent rocks or pebbles from hopping up into the engine bay, but other than that, what else is down there?
thanks.
Old Sep 11, 2005 | 08:55 PM
fwdtamiya's Avatar
Default Re: grr... front end smacked the ground... speedbump! (ekcivic9)
Header and oil pan are most likely banged up a little. I'm pretty sure you'll be fine.
Old Sep 11, 2005 | 09:03 PM
GdmLaz's Avatar
headers the most if ur an unlucky person but shouldn' be a big deal if anything at all
Old Sep 11, 2005 | 09:08 PM
ekcivic9's Avatar
thanks for the reassuring comments
ROK801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">so today i was getting out of the mall like i always do. im driving at about 30mph, and i always go over this speedbump at this speed.</TD></TR></TABLE>
jesus, i hope its not a big bump...
everything should be good... if you have an oil spot or coolant spot under your car in the morning you should worry a little bit, but if its dry i wouldnt fret...
Old Sep 11, 2005 | 09:25 PM
Vintech's Avatar
Default Re: grr... front end smacked the ground... speedbump! (fwdtamiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fwdtamiya &raquo;</TD></TR><TR><TD CLASS="quote">Header and oil pan are most likely banged up a little. I'm pretty sure you'll be fine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">headers the most if ur an unlucky person but shouldn' be a big deal if anything at all</TD></TR></TABLE>\
Headers is anything, i've seen headers into the oil pan. But if anything you just flatened out the headers
Old Sep 11, 2005 | 09:42 PM
ekcivic9's Avatar
there was already an oil spot under there when i bought it
so if there is a coolant spot... what should i do?
Old Sep 11, 2005 | 09:44 PM
nocturnaldragon's Avatar
Chances are it hit the frame and that was all, just jack it up and take a look tomarrow you should be fine tho.
Old Sep 11, 2005 | 10:24 PM
ROK801's Avatar
Default Re: (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">there was already an oil spot under there when i bought it
so if there is a coolant spot... what should i do? </TD></TR></TABLE>
make sure you didnt bump one of the hoses loose.
Jerseyfan
Jun 10, 2008 01:21 PM
EP3 FTW
10
Jan 1, 2008 11:09 PM
.paul
Honda Motorcycles
37
Apr 13, 2006 09:31 AM
clayton bigsby
Dec 13, 2005 01:20 PM
EG_Jefro
15
Dec 6, 2004 01:16 PM
