--Quick and easy question to some of you...--
When ever I go to repalce drive shafts, I always end up getting stuck on one part. How to get the driveshaft through the Shock U-Joint. Before I just some how pryed the LCA down by undoing the shock bolt, and letting it dangle then squeeze it through, there must be a simpler way though.
How do I remove the Driveshaft from the vehicle? (already out of hub and trans.)
Thankyou
Thankyou
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arsenal »</TD></TR><TR><TD CLASS="quote">
No one else replaces axles?</TD></TR></TABLE>
you already got your answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">you already got your answer</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrDanger »</TD></TR><TR><TD CLASS="quote">i believe that is the only way to do it . the hub of the axle is to big to go through the opening of the fork . </TD></TR></TABLE>
ie. Not sure.
If I already got the answer then why did you answer? You're only serving to keep the thread up, therefor contradicting yourself.
edit--still got the hump about the steering wheel comment. No need to chase me around Honda-Tech lol
ie. Not sure.
ie. Not sure.
edit--still got the hump about the steering wheel comment. No need to chase me around Honda-Tech lol</TD></TR></TABLE>
the answer was straight forward, an axle removal is simple
https://honda-tech.com/zerothread?id=382416
search next time, kthanxbye
ie. Not sure.
search next time, kthanxbye</TD></TR></TABLE>
i was about to copy and paste the same thing.
that is a very detailed how to
