obd0 to obd1 is this the kit that I need to convert all the wiring?
Old Sep 11, 2005 | 06:53 PM
TH33G4MON3's Avatar
Default obd0 to obd1 is this the kit that I need to convert all the wiring?
I need to convert my obd0 wiring to obd1... so I was just wondering if this kit I found will do what I need? thanx for any and all help!
http://www.rywire.com/sitob161.shtml
is that everything I need? $190
thanx guys
Old Sep 11, 2005 | 06:59 PM
beyondspexj's Avatar
yes sir. atleast with the dizzy clip over, if you ever go back to obd0 for whatever reason you wont have to rewire. but thats all you need ( besides a 4 wire 02, obd1 fuel injectors, fuel injector clips that are for the obd1 injectors, and a obd1 ecu)
Old Sep 11, 2005 | 07:23 PM
TH33G4MON3's Avatar
Default Re: (beyondspecs_jamar)
I have the whole si harness in my car now and I need to convert it all to obd1. so that will convert it all I have the injectors and everything else becuz I'm swapping the b16a2 obd1 into my car that had an si in it... so will this convert it all?
Old Sep 11, 2005 | 07:31 PM
88 rex's Avatar
Default Re: (TH33G4MON3)
Give rywire a call
Very helpful with me on the phone.
Old Sep 11, 2005 | 07:57 PM
TH33G4MON3's Avatar
Default Re: (88 rex)
ok I'll call them tomorrow thanx
Old Sep 11, 2005 | 08:09 PM
SiR Inspired ED7's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (TH33G4MON3)
Don't forget to buy an ecu
Old Sep 11, 2005 | 08:40 PM
vw eater's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (88 Crx Si)
i just converted to obd1 and i used my obdo injectors.. on my 90 si w/b16a
Old Sep 11, 2005 | 10:49 PM
TH33G4MON3's Avatar
don't worry I have the ecu yeah I'm sure it wouldn't be that big of a dif with the obd0 injectors but I have everything... I have the whole obd1 swap I just need to convert the wiring and get it going
the shift linkage is 90-93 integra right? and will anything else work?
Old Sep 11, 2005 | 11:19 PM
NikoZai's Avatar
If you want us at Rywire to convert your Si harness completely for your new engine you can send it to us along with the OBD1 B16 harness and we'll repin your injector run and distributor, plus we'll relocate your fan switch and run the new sensors through your stock harness as if it came from Honda exactly for your B16 in a CRX/civic
Give us a call at the # on the site, i'll clarify anything you have questions on.
Checkout http://www.droppedcrxsi.com for more swap how-to info (b16 & GSR)
~ Peter @ Rywire
Old Sep 11, 2005 | 11:36 PM
TH33G4MON3's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (NikoZai)
yeah I was gonna give you guys a call tomorrow thanx alot
Old Sep 12, 2005 | 12:06 AM
4runner's Avatar
dont mean to jack thread
is it worth wiring up the obd1 for the d15b or should i just stick with obd0 dohc zc?
Old Sep 12, 2005 | 07:15 AM
TH33G4MON3's Avatar
Default Re: obd0 to obd1 is this the kit that I need to convert all the wiring? (88HaveFun)
? I'm not sure... does it matter? go with whats easier for you
Old Sep 12, 2005 | 08:08 AM
vw eater's Avatar
this is where i got all of my ob1 conversion parts, was more then happy w/there products
Modified by vw eater at 1:50 AM 9/13/2005
Old Sep 12, 2005 | 09:12 AM
TH33G4MON3's Avatar
Default Re: (vw eater)
looks good I just need all the wiring conversions tho rywire has what I need I'm pretty sure I'm just going to call them today
Dkahn18
Feb 18, 2009 04:41 PM
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
91dxcrx
Jan 22, 2006 09:27 AM
Mefain
Feb 16, 2004 09:39 PM
ProJectCvic
Jul 12, 2003 09:20 AM
