stock head gasket vs H.G. spacer on turbo crx
Old Sep 11, 2005 | 05:10 PM
91backslash's Avatar
Default stock head gasket vs H.G. spacer on turbo crx
i have d16a6 block with y8 head, i have a t3 super 60 turbo and i am wondering if the compression is going to be ok with a stock head gasket, i am running into problems with the spacer and im sick of dealing with it. so my question to be answer is will the stock d16 head gasket be fine with the turbo?
Old Sep 11, 2005 | 07:55 PM
b18-c-rx's Avatar
Default Re: stock head gasket vs H.G. spacer on turbo crx (91backslash)
depends on how much boost
Old Sep 11, 2005 | 10:14 PM
NastyHabitzCRX's Avatar
should be fine, if theres any doubt use some ARPs and torque them a little tighter than what ARP recommends
Old Sep 12, 2005 | 10:22 AM
okay, head gasket is off now and i will go get a stock one tommorow, i talked to my buddy and he said he uses his stock head gasket and it is fine as long as you keep air to fuel in check.
Old Sep 12, 2005 | 10:24 AM
im only running 8 psi at all time also.
Old Sep 12, 2005 | 01:21 PM
crxkenny's Avatar
Use a Cometic head gasket. They are available in 75.5 76 77 78 and 79 mm. diameter and thicknesses from .027" all the way to .120". Just choose the thickness you need. And whatever you do, DO NOT "torque them a little tighter than what ARP recommends"!
Old Sep 13, 2005 | 06:15 AM
the thing is i do not know what i need, adam with the white hatch from davison said i would be alright with the compression but that is why i was double-checking. crxkenny were you the flat black rex that met at his house for the dream cruise? i was in the srt4
Old Sep 14, 2005 | 11:46 AM
crxkenny's Avatar
Default Re: (91backslash)
I was at the dream cruise-but not in a Honda.
nebulight
Aug 13, 2006 10:00 AM
ejectseat
May 9, 2003 05:38 AM
BoostinDC2
Feb 19, 2002 09:08 PM
