UNLowering your car - What are the effects?
Old Feb 27, 2002 | 11:36 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default UNLowering your car - What are the effects?
Will unlowering the car have any negative effects? In other words, will putting the suspension back to stock cause the suspension to be loose, or stretched out in anyway?
Thanks
Old Feb 27, 2002 | 11:42 AM
TheShad0w's Avatar
Default Re: UNLowering your car - What are the effects? (GoLowDrew)
only problem i can see is accidents since your used to the previous handling..
Old Feb 27, 2002 | 11:46 AM
justinCO's Avatar
Camber would probably change I would imagine...would need to re-align.
Justin
Old Feb 28, 2002 | 06:33 AM
GoLowDrew's Avatar
Old Member
25 Year Member
What about the joints and bushings?
Old Feb 28, 2002 | 06:57 AM
Warren's Avatar
Wrong-Way Wang
No, in fact, you'll probably end up with better handling:
a) your roll center will probably be lower
b) more shock travel
c) more ground clearance
d) easier on cv joints
My race car (ITR) is currently higher than stock, and it runs just fine, thanks. Just make sure you get the toe fixed when you change the height. The only real negative is that you'll lose some camber, but not enough to cry about if it's a street car.
Warren
Old Feb 28, 2002 | 07:33 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: UNLowering your car - What are the effects? (Warren)
Better handling? Isn't lowered (more negative camber) offer better handling?
.water
Suspension & Brakes
11
Oct 23, 2005 08:24 AM
DaveSi677
Sep 22, 2004 01:25 PM
p1driftfiend
Aug 12, 2004 06:41 AM
Greyout
18
Aug 4, 2004 12:47 PM
R_Machine
Sep 23, 2003 12:27 PM
