Are all rear trailing arms the same?
Old Sep 11, 2005 | 02:59 PM
94rs-turbo's Avatar
Default Are all rear trailing arms the same?
i converted my car to 5 lug but my driver rear trailing arms is bent, so can u use my stock trailing arm and put the 5 lug hub on my stock trailing arm? i know there is a diff part # for them but I want to know what if any diff. there are.
Old Sep 11, 2005 | 04:11 PM
.RJ's Avatar
.RJ
Default Re: Are all rear trailing arms the same? (94rs-turbo)
They are the same between RS/LS/GS/GSR/ITR Just unbolt the 5-lug hub and move things over.
I dont remember where the ABS sensor mounts though - that could be different - but the spindle bolts to the trailing arm, you should be able to swap those over if there is a difference. Most 94+ cars came with ABS though.
Rene M's Avatar
Not if you are using the itr shocks..
Old Sep 11, 2005 | 04:14 PM
.RJ's Avatar
.RJ
Default Re: Are all rear trailing arms the same? (Rene M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M &raquo;</TD></TR><TR><TD CLASS="quote">Not if you are using the itr shocks..</TD></TR></TABLE>
Shocks dont bolt to the trailing arm
Old Sep 11, 2005 | 04:17 PM
Rene M's Avatar
Default Re: Are all rear trailing arms the same? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Shocks dont bolt to the trailing arm </TD></TR></TABLE>
Good call, i need to read I killed quite a few brain cell at a wedding this weekend which was a three day drinking fest with a 20 min wedding.. Sorry for the wrong info.
Old Sep 11, 2005 | 04:32 PM
SilverDc2's Avatar
their a different part number because the bushing on the arm is a bit stiffer, when i did my 5lug conver the arm look very similar..seem like the actual position seemed abit off, by that i mean the offset might be off 1 or 2 try it, let us know.
Old Sep 11, 2005 | 04:52 PM
R you serious's Avatar
Default Re: Are all rear trailing arms the same? (SilverDc2)
DA integra is slightly different, but negligible.
Old Sep 12, 2005 | 04:15 PM
94rs-turbo's Avatar
Default Re: Are all rear trailing arms the same? (R you serious)
thanx for the info
Old Sep 12, 2005 | 05:11 PM
Naruto's Avatar
it will work....I've done it on mine. The trailing arm will go on. The only thing you really have to watch out for is those 4 star or torx bolts aside from the spindle nut. If they're frozen on there, soak it with LOTSA PB before you even attempt to take them off. Reason being....if you strip the head on even ONE of them...you're fuct......
solid gsr
Nov 19, 2006 07:26 PM
NXSpoon
Aug 7, 2006 12:55 AM
the_illest_soldier
Apr 4, 2005 04:27 AM
bgod
Sep 26, 2004 04:32 PM
One Bad GeeSeeR
Jun 24, 2004 02:49 PM
