Compression check
Old Feb 27, 2002 | 10:54 AM
sensaiGen5's Avatar
Default Compression check
I have to do a compression check on my JDM B16 and i was wondering. How do i perform one of these? Also are there any difference in the jdm numbers vs the USDM bi6'scompression numbers?
Thanks
Evan
Old Feb 27, 2002 | 11:54 AM
3rdGteg's Avatar
Default Re: Compression check (sensaiGen5)
purchase a compression gauge.
Old Feb 27, 2002 | 11:57 AM
sensaiGen5's Avatar
Default Re: Compression check (3rdGteg)
WHaaaaa
I have the gauge i was looking on how to perform the check. I was told you had to put in the spark plug hole and crank the motor!!!
Old Feb 27, 2002 | 12:04 PM
fixhondas's Avatar
Remove all four spark plugs, disable the fuel system, be sure battery is fully charged, hold throttle wide open, crank- watch the guage for the number of "puffs" it takes to reach peak PSI. repeat for each cylinder. If one cylinder reads low- squirt a little oil in it and recheck- if the number jumps significantly you probably have bad rings in there.
EdwinCheng
May 8, 2014 02:26 PM
JSM-FA5
Sep 2, 2012 08:28 PM
sony224422
Dec 5, 2007 06:28 PM
jorge59la
Mar 16, 2007 10:34 PM
Evil DOHC
Aug 2, 2001 02:22 AM
