trying to wire vtec ????? confused
Old Sep 11, 2005 | 11:25 AM
jdmbreed's Avatar
Default trying to wire vtec ????? confused
this is where the pressure switch should be correct???? i heard some of the jdm motors didnt come with them can someone tell me
and this is where my pressure switch is hooked up now but i dont know what it is and im almost positive its not the pressure switch can someone tell me if it is or if its not and what should be there if not?????
[IMG]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTA2MjA4OTZzNDEzZGZkMzF5NTQx[IMG]
Old Sep 11, 2005 | 11:42 PM
NikoZai's Avatar
Default Re: trying to wire vtec ????? confused (jdmbreed)
you can either put a oil pressure switch there.
Or you can tap the VTEC solenoid wire with the VTEC oil pressure wire. It will work too.
Old Sep 12, 2005 | 07:39 AM
SKDRCR's Avatar
Default Re: trying to wire vtec ????? confused (NikoZai)
https://honda-tech.com/zerothread?id=1004852
Old Sep 26, 2005 | 07:56 AM
Favalous's Avatar
I have a similar problem Niko. I have the oil pressure swith hole to fill as well. What do I need to do with it to make the vtec work? i have a d16a6 block with the z6 head. I know how to wire the solenoid to activate, but what do I do with the oil pressure switch hole?? HELP.
See Are X
Sep 4, 2024 03:31 PM
91 DA Revived
Oct 28, 2010 05:25 PM
shepn8tr
Apr 13, 2008 06:44 AM
blueeg
Apr 25, 2006 11:16 AM
