Question about the ITR rear lower tie bar....
Will an ITR rear tie bar fit an EK?? Also, I'm putting in an ITR 22mm swaybar and was wondering if the tie bar will sitll fit? Should I get an SI sway bar??
thanks
thanks
Will
I've got an ITR rear sway bar on my EK along with a Spoon rear lower tie bar. Instead of spending the money a Spoon bar I would recomend getting a Skunk 2 rear lower tie bar. The design is the same as the Spoon bar. Here's a pic of my setup:
Merrit, it appears from the photo above that you have changed the way the Type-R rear swaybar is mounted on your EK. It look as if you have done away with the "black mounting brackets" (photo below) and have now mounted the swaybar directly to the subframe. Can you let me know? I'm just curious to know why you changed it.
isnt that a reinforcement braket so the swaybar doesn't rip the subframe??
i just bought a Beaks one.
http://www.geocities.com/BeaksProducts
j
[Modified by B18C1_EK, 6:39 PM 2/28/2002]
j
anekin007
10
Sep 30, 2004 02:03 PM
