What is this?
Old Sep 11, 2005 | 11:13 AM
XtremeSpeed's Avatar
Default What is this?
Hi, what is this? the part i circled in the red. the p=art with all those lines going down it. the one on the other side is broken, and make a wierd noise when it moves. what can i do to fix it, or replace it?
The Phil's Avatar
Default Re: What is this? (XtremeSpeed)
Where on your car is that?
EDIT: If that's your brake disk and axle, maybe the ABS sensor is hitting the wheel speed gear thing?
Old Sep 11, 2005 | 11:34 AM
scootertribe's Avatar
Default Re: What is this? (The Phil)
looks like he's looking down on a brake rotor...
Old Sep 11, 2005 | 11:39 AM
The Phil's Avatar
Default Re: What is this? (scootertribe)
On second thought, it might be a rear brake rotor and hub. So yes, it could be the speed sensor hitting the geared wheel.
Old Sep 11, 2005 | 11:43 AM
yes, it is the rear brake rotor and hub. that piece seems to be hitting something since it is cracked and making this wierd sound. also my brakes r really wierd for the first 2 min the car is on, where is clicks and doesnt wanna brake too well, and u hear this clicking sound inside the car, then all of a sudden, the sound stops and it works perfect again. could that be causing this.
Old Sep 11, 2005 | 11:48 AM
The Phil's Avatar
Default Re: (XtremeSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtremeSpeed &raquo;</TD></TR><TR><TD CLASS="quote">yes, it is the rear brake rotor and hub. that piece seems to be hitting something since it is cracked and making this wierd sound. also my brakes r really wierd for the first 2 min the car is on, where is clicks and doesnt wanna brake too well, and u hear this clicking sound inside the car, then all of a sudden, the sound stops and it works perfect again. could that be causing this.</TD></TR></TABLE>
Remove the ABS sensor from that wheel. Take a better shot of the cracked part, because there doesn't seem to be anything wrong here.
Old Sep 11, 2005 | 12:32 PM
thats not the cracked one. the other side is, i just couldnt take a good pic of that side. basically it is cracked from the hub towards the rotor. and it is pushed back towards the hub more, causing it to rub.
Old Sep 11, 2005 | 03:37 PM
The Weather Man's Avatar
from a distance it looks like a roller bearing - not saying that it is - but doesn't the hub have a roller bearing inside of it..............
casmello
Oct 16, 2005 11:14 AM
wessieball
Aug 8, 2003 07:26 AM
RedKroovy
Jul 17, 2003 04:46 PM
CapnChunk
Apr 15, 2003 08:29 PM
onyx00
Jan 19, 2002 06:37 PM
