Question of the month: Who....
Old Sep 11, 2005 | 09:47 AM
MackDad's Avatar
Default Question of the month: Who....
Who manufacturers the pistons and rods, along with other internals, for Honda?
Old Sep 11, 2005 | 10:26 AM
OEM_ASSASSIN's Avatar
OBX
Old Sep 11, 2005 | 10:34 AM
MackDad's Avatar
Default Re: (OEM_ASSASSIN)
I'm sorry, let me rephrase this....
Who manufactures the OEM pistons and rods, along with other internals, for Honda of Japan/America?
The reason I am asking this is because I was told by someone that Honda does not make their own internals for their engines, but instead relies on an outside source. I know I have seen the name stamped on the engine blacks and transmissions housings as well. but I can't remember the name.
Old Sep 11, 2005 | 01:15 PM
pentaq's Avatar
Default Re: (MackDad)
My answer is not direct: piston rings are made by TEIKOKU and RIKEN, so these companies can possibly supply Honda with their other products.
Old Sep 11, 2005 | 02:30 PM
The Destroyer's Avatar
Default Re: (pentaq)
Sainkee...made from racin'
Old Sep 11, 2005 | 03:40 PM
satan_srv's Avatar
Nissin does a bunch of their stuff too.
Old Sep 11, 2005 | 05:00 PM
kulrevon's Avatar
Default Re: (satan_srv)
I say lets find out who makes there pistons. It would be great to get a high compression stock piston that doesnt destroy the frm walls.
Old Sep 13, 2005 | 07:13 PM
satan_srv's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">I say lets find out who makes there pistons. It would be great to get a high compression stock piston that doesnt destroy the frm walls.</TD></TR></TABLE>
Jun already makes a high comp frm compatible piston.
Old Sep 13, 2005 | 07:31 PM
lude_behavior's Avatar
Where are they available?
Old Sep 13, 2005 | 09:07 PM
BlueLude94's Avatar
high compression doesn't help the FI folks
Old Sep 14, 2005 | 06:57 AM
Honda318dx's Avatar
Default Re: (BlueLude94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude94 &raquo;</TD></TR><TR><TD CLASS="quote">high compression doesn't help the FI folks</TD></TR></TABLE>
Fine, use a F23 block, bore it out, use whatever pistons.
Old Sep 14, 2005 | 08:16 AM
Dougs96SI's Avatar
Default Re: Question of the month: Who.... (MackDad)
A low compression piston would be better
Old Sep 14, 2005 | 08:18 AM
The Birdman's Avatar
Default Re: (lude_behavior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude_behavior &raquo;</TD></TR><TR><TD CLASS="quote">Where are they available? </TD></TR></TABLE>
Not trying to steal the thread, just giving some info...
They are 12.3:1 compression, manufactured by the company Cosworth for JUN. http://lib.store.yahoo.com/lib...h.jpg -This is a pic of one of the jun pistons. It's kind of hard to get a hold of these pistons but try pm'ing the honda-tech user JUNBB1, he has them I believe.
I was opting for these pistons for a while, and in an attempt to get them without the hassle of finding someone who still stocks them, I contacted cosworth. They are based out of UK but have a place in Cali as well. http://www.cosworth.com/contactus.php
I talked to them about producing the same piston and selling them directly to the public but I obviously didn't think this through because JUN came up with all the specifications of the piston and so it is therefore THEIR piston and cosworth cannot produce it as its own design. JUN only produces their pistons through cosworth because of the forging tools they have access to.
I tried to get a group buy going to convince Cosworth to produce a similar piston of its own design, but I didn't get much feedback on honda-tech and shortly gave up when Cosworth did not return one of my last calls.
Also, if we could convince them that the demand is high enough for frm compatible pistons, they would probably produce a lower compression piston as well (TURBO BOYS).
Old Sep 14, 2005 | 04:12 PM
ALTERED4's Avatar
Default Re: (jd3jdm)
a forged, high compression, frm compatible piston??? where do i sign???
Old Sep 14, 2005 | 05:36 PM
tdo's Avatar
tdo
Default Re: (ALTERED4)
i see YSK stamped on a lot of trannys.
ITR_HO
Feb 20, 2007 06:12 PM
str8sleepr
56
Apr 10, 2006 11:22 AM
*Boostwerks*
Aug 6, 2005 07:28 AM
shorto85
Jul 24, 2005 10:05 PM
