gsr ecu on a 2.2 in a 93 h/b
Old Feb 27, 2002 | 10:07 AM
homer's Avatar
New User
Default gsr ecu on a 2.2 in a 93 h/b
I'm running a gsr ecu in my 93 h/b with a H22. The car is runnind like crap right now spitting and sputtering. Its also throwing a 41 code (heated O2) so I went and bought a new sensor pulled my out and checked them and they both read the same on the meter, so I took the new one back. I have a turbo to put on as soon as i get this thing running right. If the gsr ecu is ok when I get injectors should I get them for a gsr or a prelude?
Old Feb 27, 2002 | 10:39 AM
aklucsarits's Avatar
New User
Default Re: gsr ecu on a 2.2 in a 93 h/b (homer)
What year H22a? The 92-96 use peak and hold injectors. The 97+ use saturated injectors. All GS-R ECUs are for saturated... I had a semi related thread I started yesterday... https://honda-tech.com/zerothread?id=136165
Andrew
Old Feb 27, 2002 | 10:41 AM
New User
Default Re: gsr ecu on a 2.2 in a 93 h/b (aklucsarits)
Also, either way the stock GS-R maps run dangerously lean on an H22a... Have you had it reprogrammed?
Andrew
Old Feb 27, 2002 | 10:59 AM
homer's Avatar
New User
my motor is a 93 jdm 2.2 and the ecu is a usdm 94 (stock). I also wired in a res. pack for the injectors and it made my cars idle go up and down up and down. If the gsr ecu runs lean on a 2.2 I guess I should get the 2.2 ecu because I have a turbo to install when I get the car running right.
Old Feb 27, 2002 | 11:23 AM
New User
https://honda-tech.com/zerothread?id=123055
GS-R ECU runs LEEEEEAAAAAN!:
The A/F is about 13.7-14.9 for most of the powerband... dangerous for a stock motor, and definitely fatal for a turbo...
Andrew
Old Feb 27, 2002 | 11:43 AM
fixhondas's Avatar
Fuel maps for a 1.8L used on a 2.2L = lean and will give you O2 code(s)- at least bump your fuel pressure up before you toast your engine and get the right program in there.
Old Feb 27, 2002 | 11:44 AM
Mike K's Avatar
I heard the GSR ECU was a hot setup.
My friend ran this setup at 60 or 65psi fuel pressure, I believe.
Old Feb 27, 2002 | 02:04 PM
gsrvx's Avatar
New User
Default Re: gsr ecu on a 2.2 in a 93 h/b (Mike K)
What is a healthy A/F ratio?
-Rod
Old Feb 27, 2002 | 03:43 PM
BoM's Avatar
BoM
Default Re: gsr ecu on a 2.2 in a 93 h/b (RK)
that year prelude has 330cc injectors
if you bought stock integra injectors they'll starve the engine.
toast9897
Feb 28, 2010 06:48 PM
acuradriva
Oct 27, 2005 09:43 PM
servion
Jun 10, 2002 08:03 AM
SiRCal
May 3, 2002 05:51 AM
