IACV 3wire to 2 wire
Old Sep 10, 2005 | 11:28 PM
Jon at Titan's Avatar
Default IACV 3wire to 2 wire
Hey Guys I have a little problem here, I have searched over and over, found some helping Articles but no luck,
I just recently completed a auto to manual swap for d16y8 Engine, EJ8
I converted to OBD1
I changed over the Intake manifold from auto one to a manual one but i did USE the Auto Throttle Body
I completed the Wiring and ECU pinning Shown here : https://honda-tech.com/zerothread?id=852762
Im still getting The surging, I dont know if it could be the TB or 2 wire plug, I cut it from a ZC manual Engine,
If anyone can help me diagnose this It would greatfull guys,
Anyone think it could be the Auto Throttle body, Salvage yards are closed on sundays, so i cant get one, anyone in orlando can get me one i would buy it.
Im all out of ideas, and its 3 AM here in florida,
Any help guys
thanks
Old Sep 10, 2005 | 11:35 PM
hatchi's Avatar
Default Re: IACV 3wire to 2 wire (El_buster)
you will need to use manual tb. are you getting code 14??
Old Sep 10, 2005 | 11:38 PM
thanks, have not checked the CEL yet will do that when i have more light tomorow, but im getting surging at and idles at 1500 to 2000 RPMS
Old Sep 10, 2005 | 11:40 PM
I used a ZC 2 wire plug which the colors are different than the ones in the instructions, could it be that as well, Its a green colored plug, with back with yellow stripe and blue and yellow stripe, I hope its just the TB
Old Sep 10, 2005 | 11:46 PM
hatchi's Avatar
Default Re: (El_buster)
try throwing in a manual tb and the plug it doesnt matter as long as its round and 2 wire plug. just dont use the middle wire/orange. leave it hanging. wire them up. reset ecu and see if it will still do it. If it does switch the wires and reset again
Old Sep 10, 2005 | 11:47 PM
Awsome thanks for the Info and help will try that tomorow man
Old Sep 11, 2005 | 04:38 PM
Thanks Hatchi Worked out fine, used a Manual Throttle body, works fine now.
tim73
17
Jan 11, 2015 08:08 AM
s73
Jun 10, 2004 11:43 PM
Stoich
10
Mar 22, 2004 03:38 PM
Spectral49
Nov 18, 2003 11:50 PM
