How much can stock LS block handle boosted??
Old Sep 10, 2005 | 09:12 PM
95integraLS003's Avatar
Default How much can stock LS block handle boosted??
With everyone on HT there has to be some serious boosted LS tegs.. On stock block and internals whats the highest psi you have tuned at?
Old Sep 10, 2005 | 10:11 PM
rsintegra's Avatar
Default Re: How much can stock LS block handle boosted?? (95integraLS003)
It's not really a matter of how much PSI you boost, but how much whp the car can handle. The stock LS can handle around 300whp on average (some people can tune it better and get more hp). I heard that the LS can do 8 PSI, which is bs. There are quite a bunch of people here with boosted LS hitting 10+ PSI. I think adseguy here is doing 16 PSI, stock block...hitting around 280whp I think. It all depends on the tune and setup.
Old Sep 10, 2005 | 10:27 PM
Johnny_Rocket's Avatar
Default Re: How much can stock LS block handle boosted?? (rsintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsintegra &raquo;</TD></TR><TR><TD CLASS="quote">It's not really a matter of how much PSI you boost, but how much whp the car can handle. The stock LS can handle around 300whp on average (some people can tune it better and get more hp). I heard that the LS can do 8 PSI, which is bs. There are quite a bunch of people here with boosted LS hitting 10+ PSI. I think adseguy here is doing 16 PSI, stock block...hitting around 280whp I think. It all depends on the tune and setup. </TD></TR></TABLE>
True... I ran 7 on my stock LS and blew the **** out of it... I didn't really have it tuned. Tuning is what makes it or breaks it
Old Sep 10, 2005 | 10:39 PM
IntegraBoy04's Avatar
Default Re: How much can stock LS block handle boosted?? (JohnnyH)
I run 10 low, 17 high on my completely stock motor ls. I'm making about 320ish wheel on high boost....but I have a very very good tune.
Old Sep 10, 2005 | 11:12 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnyH &raquo;</TD></TR><TR><TD CLASS="quote">Tuning is what makes it or breaks it</TD></TR></TABLE>
That would be the only answer
Old Sep 10, 2005 | 11:24 PM
BlackDAy's Avatar
Default Re: How much can stock LS block handle boosted?? (IntegraBoy04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraBoy04 &raquo;</TD></TR><TR><TD CLASS="quote">I run 10 low, 17 high on my completely stock motor ls. I'm making about 320ish wheel on high boost....but I have a very very good tune.</TD></TR></TABLE>
DAYYYYAAAM
Old Sep 11, 2005 | 07:50 AM
adseguy's Avatar
Default Re: How much can stock LS block handle boosted?? (Palmy Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Palmy Blue &raquo;</TD></TR><TR><TD CLASS="quote">How long do you want your motor to last???</TD></TR></TABLE>
haha.....right! the roughest thing on the engine is starting up cold and revving. Power only accounts for 10% engine damage according to Corkey Bell, author of maximum boost. Now if you have a bad tune throw all that out the window . I have 300whp at 16PSI--check sig and tuned it myself. She runs great and will continue to run great for a LONG time .
I'd say shoot for around 280whp and you'll be set. The most important part is your tuner by far.
Old Sep 11, 2005 | 08:05 AM
5thGenFanatic's Avatar
Default Re: How much can stock LS block handle boosted?? (adseguy)
i have a friend (99lspwr) that lives down the road...he had a 92 hatch with my old integra motor..usdm with 175,000 on it with stock internals...running a greddy 18g with an safc and wideband...he ran it like every week down the track for like a year and a half and pushing 17 psi...never had 1 problem with it...ran mid 11s all day its all about tuning these motors will handle a lot if u just make sure ur air/fuel is properly tuned to eliminate detonation...detonation is the killer of turbo honda...it will **** up piston heads in not time..this is why some people running 6 or 7 psi grenade in 1 run...and others run 17-20 and have no problems...invest in a wideband to help u make sure ur air/fuel is str8 while increasing boost and pwer...its 300 bucks new and will save ur motor if u know how to use it ..p.s u can im him and ask how he was tuning it but he likes men... j/k frank if u read this..u know i love ya
Old Sep 11, 2005 | 08:06 AM
Default Re: How much can stock LS block handle boosted?? (5thGenFanatic)
wow my grammar is horrible today sorry
Old Sep 11, 2005 | 09:53 PM
LSRracing95's Avatar
well as most people say, tuning DOES make or break the power output and the reliabilty of your motor... i would honestly only run low boost on a stock ls motor because of the weak honda rods that the LS motor is accompanied by... if you build up the block though and put some better rods and pistons in there the more will be much more reliable and more prone to holding higher boost safely.. not to mention youll be making more power.
Old Sep 11, 2005 | 10:14 PM
.one lane's Avatar
.likes trains
This is kind of off topic, but do you guys have any recommendation of a tuner in so cal?
Old Sep 11, 2005 | 10:47 PM
Milanogisser's Avatar
rule of thumb on stock B series blocks is nothing over 11psi....check out homemadeturbo.com....
Old Sep 12, 2005 | 04:29 AM
Default Re: (Milanogisser)
booo..b series motors can handle much more than u think.... as long as u know the limits and potential of the motor and are good at tuning and understanding tyhe operation you can run high boost safely...also the rods and bolts are not the best in the world...resleeving and new rods would be safer...but a stock block will handle the power
Old Sep 12, 2005 | 08:50 AM
Default Re: (5thGenFanatic)
It mostly depends on the tune though. I would never even consider running that much boost if I didn't have my car tuned by a badass.
Old Sep 12, 2005 | 06:53 PM
adseguy's Avatar
Default Re: How much can stock LS block handle boosted?? (LSRracing95)
This is why the Integra Forum should never mention the word turbo. **** flies everywhere and I always have to clean it up! GHEYNESS to the MAXX. READ UP OR SHUT THE **** UP!
sorry had to vent
Old Sep 12, 2005 | 07:04 PM
You have to clean it up?? Like you know everything or something???
Old Sep 12, 2005 | 07:14 PM
adseguy's Avatar
Listen, I'm not trying to start anything, but I come in this forum once in a while and you can agree with me a lot of turbo talk in here is just sooooo false. I try my best to help clarify or stop the spreading of horrible rumors.
I answered the post honestly and to my "pretty good" knowledge I'm right. This is pretty basic stuff to me and I'd like to help people out, but when people blurt things like "no more then 10PSI" or "the stock rods won't hold up they are the weakest" I want to cry.
Old Sep 13, 2005 | 05:45 AM
[QUOTE=95 SE stock block TURBO Teg - 303whp / 260ft/lbs
Uberdata/Crome/TurboEdit Tuner and ECU chipping - Chicagoland and Central Missouri areas[/QUOTE]
exactly
Rustyman14
Feb 6, 2006 08:37 AM
buttsneeze
Sep 15, 2004 09:03 AM
SJcivic
Aug 19, 2004 10:10 AM
street dreams
Feb 1, 2004 07:05 PM
p1ccoloz
May 1, 2003 02:09 PM
