Mid-Atlantic (Sales) VA, DC, and MD
Built B18C1 GSR Complete Engine (0 miles)
Old Sep 10, 2005 | 05:46 PM
crxhybrid1320's Avatar
Default Built B18C1 GSR Complete Engine (0 miles)
Friend is selling a freshly built B18C1 with O miles. His car was stolen before the engine was installed so he has nothing to put the engine into. Machine work on the block was done at Benson Machine shop including balancing of bottom end components. Have recieps for internal components from Race Engineering.
$3000 o.b.o (pick-up only)
B18C1 Block:
CP Pistons and Rings - 10.1 compression (overbore)
Eagle Rods
OEM Crank
OEM Acura Bearings and Thrust Washers
OEM Type-R Oil Pump
OEM Timing Belt
OEM Oil Pan
B18C1 Head:
OEM Headgasket
OEM B18C1 Cams
Ferrea Competion Valves,
Dual Valve Spring, Retainers,
and Valve Locks
ARP Headstuds
OEM Valve Cover
OEM Distributor
Vtec Solonoid & Pressure Switch
Modified by crxhybrid1320 at 12:43 AM 9/27/2005
Old Sep 13, 2005 | 07:30 PM
Default Re: Built B18C1 GSR Complete Engine (crxhybrid1320)
Bump!
Old Sep 20, 2005 | 06:49 PM
Bump!
Old Sep 21, 2005 | 05:54 PM
A's 94 GSR's Avatar
BG-33P
BUMP for the guy...
Sorry about your teggy loss also...
Old Sep 24, 2005 | 04:08 PM
vtec99's Avatar
how much just for the head
Old Sep 25, 2005 | 08:41 AM
Default Re: (vtec99)
Its already assembled with new head gasket and arp head studs already torqued and cams installed. Buy everything and sell the block yourself.Pm me with any offers.
Old Sep 26, 2005 | 12:02 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: (crxhybrid1320)
Send me pics! Does it have a dizzy, valve cover, vtec solenoid, all sensors?
Old Sep 26, 2005 | 08:41 PM
Default Re: (White Smoke)
complete with everything to make it run!
Old Oct 6, 2005 | 06:48 PM
jdmgsr_ej1's Avatar
is thi ssold yet gotta see how funds will look to let u kno wassup
MONSTERek4
Jan 7, 2010 12:14 PM
TannerCB
May 18, 2009 12:50 PM
TannerCB
Dec 14, 2007 01:58 PM
TannerCB
May 25, 2007 04:54 AM
TannerCB
May 14, 2007 03:39 AM
