d15a1/d15b2 motor swap
Old Sep 10, 2005 | 04:10 PM
91civicsedan's Avatar
Default d15a1/d15b2 motor swap
I've got a project im working on. I'm trying to put a d15b2 motor out of a 91 civic dx into an 87 crx. the crx has d15a1 carb motor. the d15b2 is fuel injected. my question is, will the d15b2 block and head bolt up and work in the crx without any problems? also, will the intake and exhaust bolt up? any help with this will greatly increase my chance of success.
Old Sep 10, 2005 | 05:52 PM
HiProfile's Avatar
Default Re: d15a1/d15b2 motor swap (91civicsedan)
I don't see why it wouldn't all fit. The only real problems are d-series trannys & axles from that era. Heads from the tegs fit on newer d's just fine. Also, lots of sohc ZC's came carb'd, which can be converted mpfi easily.
Old Sep 10, 2005 | 08:25 PM
siRhec's Avatar
you'll have to change the mounts from the old carb engine to the fuel injected one
also, the fact that the crx is a carbureted model, you will have to take both halves of the harness from the fuel injected engine in order for it to work. pain in the a$$
but very possible.
Old Sep 10, 2005 | 08:28 PM
siRhec's Avatar
oh and also on the carbureted engine, the fuel pump is located on the head,
you will have to take the fuel pump, and possibly even the tank and switch them out too.
Old Sep 13, 2005 | 04:43 AM
Default Re: d15a1/d15b2 motor swap (blkrex)
what part of the wiring harness do I have to re-use?
T12UNK5
23
Jan 13, 2024 08:19 AM
NickH93
May 25, 2015 07:11 PM
85crx
Sep 22, 2002 06:29 PM
.nate
15
Oct 12, 2001 08:57 AM
4wsB21a
Aug 30, 2001 06:46 PM
